Speedometer & Odometer calibration
JagTheOne
Slovakia
#1 Speedometer & Odometer calibration
Post by JagTheOne » Fri Aug 31, 2012 6:07 pm
Hi guys, I would like to change in the future my diff ratio from 3.54 to 3.07 and change the units from miles to kilometers thus I will need to calibrate my speedo.
The question is: who cares? :lol: sorry...
No, the question is... What are the options?
1.) I can send my speedo together with all necessary data to someone and they will do it for me. (they will change just gears in the speedo)
2.) Can I change the speedo drive gears in the gearbox? The angle drive gearbox for speedo will stay the same.
Martin
1965 Opalescent Silver Blue S1 4.2 FHC
Post by Heuer » Fri Aug 31, 2012 6:21 pm
You could either have the speedo re-calibrated or find the correct one s/h. Serial numbers of speedometers here: http://etypeuk.com/forum/viewtopic.php?t=951
If you want your existing speedo serviced and re-calibrated:
Speedograph Richfield (instrument restoration/calibration): http://www.speedograph-richfield.com/
Speedy Cables (instrument repair, restoration, calibration): http://www.speedycables.com/index.html
Speedometer calibration: http://www.westnet.com/~mfrank/Speedometer/Smiths.html
John D Ostick (instrument repairs, re-calibration): http://www.jdo1.com/
JagTheOne
Slovakia
Post by JagTheOne » Fri Aug 31, 2012 6:44 pm
Thanks David! I didn't mentioned the third option of correct speedometer because I hit Submit button instead of Preview :roll:
Now I have next question... How accurate is that database?
There is: SN 6322/03A; xxxx; 3.31; mph; 6.40x15 SP41
This is the number on my speedo with 1312 TPM. But I have 3.54 diff wich is according to Jaguar certificate original.
So I will have to look for speedo with Kmh face but with wich serial number or TPM...
Martin
vee12eman
Kiribati
Post by vee12eman » Fri Aug 31, 2012 10:43 pm
I know this doesn't help with the speedo calibration, but you can change a speedo to km/h just by changing the face - available from SNG. The odometer still reads in miles of course. I don't know whether the calibration people will re-paint the face of the speedo, so if you want a km/h face, this may be an option.
Series III FHC
JagTheOne
Slovakia
Post by JagTheOne » Sat Sep 01, 2012 5:34 am
Thanks Simon, I know about that. I will probably find correct speedometer and restore it.
Martin
Post by abowie » Sun Sep 02, 2012 1:11 am
I sent mine to Speedograph in Nottingham. If you look on their website they ask for a whole lot of information about your car to correctly calibrate it; cost me about 70 pounds plus postage. The guy I spoke to on the phone was a bit grumpy to deal with.
As I haven't yet finished putting my car back together again I can't comment on accuracy but it is certainly very clean.
Pavel Prochazka
Czech Republic
#7 HELP - Calibration at Richfields - speedo form - turns
Post by Pavel Prochazka » Thu Jan 24, 2013 3:47 pm
Hello all,
I have currently car dismantled and thus cannot verify the turns as described in Richfield's form. Should you please provide me with your numbers of cable turns per 6 drive wheel turns (as they recommend "push car for 6 wheel turns and count cable turns") I have calculated mine for 3.54 differential and 1.25 gearbox angle drive and I got number around 10 1/8. What were your results, preferably for 3.54 differential but other differentials are welcome as well.
Many thanks to all for your help,
Pavel
Dec1966 LHD OTS 4.2
Post by Heuer » Thu Jan 24, 2013 6:33 pm
Pavel
Have you checked out the list in this post?: http://etypeuk.com/forum/viewtopic.php?t=951
JagTheOne
Slovakia
#9
Post by JagTheOne » Thu Jan 24, 2013 7:14 pm
Nazdar Pavel,
I have a Series 1 4.2 FHC with 3.54 diff. The TPM on the original speedo is 1312.
Martin
Martin
