I received a new switch to replace the defunct switch, part # c33862. The new switch has 8 pins, the previous switch had 4 pins (possibly incorrect switch before?).
I have 4 wires in my harness to the wiper motor connector: they are RLG, ULG, G and YLG: I have continuity on all these wires from the switch end to the connector end. There is also a B at the connector which goes from the connector to the Wash bottle motor and from there to Ground.
All electrical diagrams (inc the original one in the owners package) show NLG in place of the ULG: as my harness is original, I am presuming (aah) that at some stage the NLG was replaced by a ULG and/or there was a constant typo along the way or there is discoloration of the wiring cover.
Also the numbering of the pins on the diagrams seems incomplete.
There is also a B ground shown on diagrams at the wiper switch but I did not have this on my switch when I removed it: it is not the B from the connector as this runs as described above.
Below is a snap shot of the wiring diagram where pin 1 is NLG (my ULG), pin2 is B ground by cable, unspecified pin # for YLG, unspecified pin # for G, pin 4 is RLG and pin 3 is not used.
I have seen the set up on my colleagues Series 2 but I cannot verify pin numbers. His appears to go as follows: RLG on pin 2, ULG on pin 4, G on pin 5, YLG on Pin 7. There is no B ground wire at all on his switch.
Can anyone tell me the correct pins on this 8 pin switch to connect these 4 wires to plus the B ground.
