Unidentified fitting on bulkhead
kingzetts
#1 Unidentified fitting on bulkhead
Post by kingzetts » Tue Nov 11, 2008 3:41 pm
Does anyone know what this is??
It is on the bulkhead between the bracket for the rear engine stabiliser and the water valve for the heater, but I don't know what it is or does. The protruding bit seems to have knurling on it under the paint.
John '62 S1 OTS (now sold)
kingzetts
Post by kingzetts » Tue Nov 11, 2008 3:46 pm
Ahh, please ignore this post. I just re-read the Haynes manual and discovered it must be the parking switch adjuster for the wipers.....
Post by Heuer » Tue Nov 11, 2008 4:06 pm
Should not be painted though as far as I am aware.
kingzetts
Post by kingzetts » Tue Nov 11, 2008 4:38 pm
Same goes for quite a lot of things in this engine bay - one of the reasons I'm taking it apart, so the whole area can be improved.
Car-Nut
Post by Car-Nut » Tue Nov 11, 2008 6:37 pm
kingzetts wrote:Same goes for quite a lot of things in this engine bay - one of the reasons I'm taking it apart, so the whole area can be improved.
Have you done anything like this before or is it a case of take a lot a lot of pictures as you go :)
daverawle
Post by daverawle » Tue Nov 11, 2008 7:05 pm
John,
take lots of pictures - but there will still be a vital one missing.
I find putting the camera on movie mode and slowly panning around can be a life-saver.
1963 OTS
kingzetts
Post by kingzetts » Tue Nov 11, 2008 9:18 pm
I've done plenty of this sort of thing before, and I love it. 911s, 924, Range Rover, Spitfire, TR7, motorbikes - just first time on an e-type.
I find good notes and sketches made during disassembly, labels attached to fittings and especially wires, lots of ziplock plastic bags with write-on labels and a good parts catalogue are all essential aids. I've not bothered with photos in the past, but with a decent digital camera now I am finding it very helpful and having to make far fewer sketches - although as Dave says there'll always be something I miss.
And it is so much more fun and less stressful when you don't have to have the car back together to go to work next day.........enough of that when I was younger!!
Dave K
Post by Dave K » Fri Mar 06, 2009 7:21 pm
I see in the photo you still have the speedo cable support clip attached, anyone know if these are still available?
Post by Heuer » Sat Mar 07, 2009 5:23 pm
Hutsons?
kingzetts
Post by kingzetts » Sun Mar 08, 2009 12:25 pm
It is only a piece of bent tin - I'd say make your own, possibly use a larger stainless steel P-clip and remove the rubber and bend to shape.
