Ok Guys ( & Girls !)
A small piece of advice please, should the quarter light seals be fitted with the longer edge of the seal< the most protruding part, around the outside. I.e closer to the bodywork.
Mine are fitted with the longer edge pushing against the frame which im not sure is correct.
any thoughts?
tim
quaterlight rubber seals
Mine are fitted with the longer edge outward, and are very probably the original ones.
Doh! another job for Winter then
1964 FHC 4.2
