inner fulcrum mounting bracket
ScottMHoffman
Topic author - Posts: 12
#1 inner fulcrum mounting bracket
Does any one know where i can find a used inner fulcrum mounting bracket
Scott M Hoffman
1966 Jag XKE
1966 Jag XKE
#2 Re: inner fulcrum mounting bracket
Why used? ... Is this part NLA?ScottMHoffman wrote:Does any one know where i can find a used inner fulcrum mounting bracket
Did you check SNG Barrat?
Their catalog shows:
"25. Inner fulcrum shaft C17008 qty 2
26. Nut NY608041J 4
27. Thrust washer C17165 8
28. Oil seal retainer C17936 8
29. Sealing ring C17213 8
30. Thrust washer C17166 8
31. Inner fulcrum shaft bearing C17167 8
32. Bearing tube S1 3.8 C17168 2 All other models C17168/1* 4
Items 26-32 are available as an inner fulcrum repair kit C17167FK which contains enough parts for one side."
1968 XKE 4.2 Roadster. 1.5 Series LHD ..
Triple Weber 45 DCOE and 123/TUNE
He's after the cast steel mounting bracket C20481 that bolts to the diff; as far as I know they're NLA.
He's after the cast steel mounting bracket that bolts to the diff; as far as I know they're NLA.
Try Richard Smith. +44 (0)1270 780954 rmj@rmjsmith.fsnet.co.uk
