Hunting for a Dual fuel pump!
Rafa
Spain
#1 Hunting for a Dual fuel pump!
Post by Rafa » Fri Sep 27, 2013 9:06 am
I've had my S3 off the road for 6 weeks waiting for a fuel pump as these have been on back order from SU (Burlens) through SNG/Martin Robey etc. I've just come off the phone to SU and they say there is another 4 weeks before they build anymore...
Anyone know how I can get hold of one? I'm going for the electronic version:
Part number: AZX1405EN Description: Dual HP Fuel Pump Electronic
but at this stage anything that works will suffice!
Many thanks.
Post by Heuer » Fri Sep 27, 2013 9:54 am
Try Hutson's - I was talking to Andy Rayner earlier this week and he said he had just had a delivery from Burlen. No idea if that includes the S3 pump, but worth a try.
Rafa
Spain
Post by Rafa » Fri Sep 27, 2013 3:58 pm
David, you hero, thanks!
Andy (who has waited 7 months for his delivery) has got one for me, albeit the electric, not electronic version, but at least the old girl will get a spin again soon!
Rafa
S3 2+2
Post by christopher storey » Sat Sep 28, 2013 7:42 am
I wasn't going to say anything, but I felt sure Andy would not have an electronic one. The last one he showed me had been on fire ! I am sure you are better off with the one you have bought
Post by Heuer » Sat Sep 28, 2013 2:54 pm
Bit alarmist Christopher, unless you have a sample of more than one. Mine seems to work perfectly unlike the second new submersible pump which is leaking.
Post by christopher storey » Sat Sep 28, 2013 3:00 pm
Well, it was sufficient to put Andy off supplying the double electronic ones . As you know, he is not someone who likes things to go wrong, particularly spectacularly, which this was . Even the housing had melted
Post by Heuer » Sat Sep 28, 2013 4:58 pm
Ahh - mine is a single electronic one.
Woolfi
Post by Woolfi » Wed Oct 02, 2013 6:28 am
I have mounted this pump from Hardi in my EV12 S3. Volkswagen is using this pump for boat-motors. Should by high quality and very reliable.
Mine is working well since 4 years.
http://www.ebay.de/itm/Hardi-Kraftstoff ... 798wt_1139
Regards Wolfgang Gatza
V12 Epyte
Post by V12 Epyte » Wed Oct 02, 2013 6:07 pm
Before fitting a new petrol pump to a Series 3 I would suggest testing the voltage output from the Butec regulator. My Series 3 has just been returned to the road after a long restoration and it burned out the petrol pump after a month ( non electronic type). It turned out that the Butec regulator was passing between 17 to 18 volts, This was also a "new " item purchased during the restoration. I put a secondhand regulator on and the old petrol pump back on and it has run fine since. I have bought another Butec regulator and this is passing 14.15 volts,which has now been fitted and everything is still running ok.
