I decided to restore my dials/gauges myself however on removing them from the dash panesl and fully disassembling them I've found a few issues.
Firstly, on the back of the speedo case the odometer trip cable entry point has been lead soldered to the casing (see below). Is this normal or more likely to be an addition from the PO ? Furthermore, is this going to cause a problem when I come to have the cases plated ?
Secondly, the front face plates of the Water & Fuel Gauges are peeling.
As the workings of the 2 gauges seem fine I'd ideally just like to find replacement faces. Were these Smiths gauges put into anything other than the S1 ?
Alternatively, has anyone tried painting these & had satisfactory results ?
If so what paint - satin black ?
Any advice gratefully received.
Neil
