Dave,
I found this helpful ; it's showing what you see when looking at the
INSIDE of the plug/socket interface, so looking at the PINS,
NOT from the back of the plug/socket where the wires go in (which would be a mirror image of course) - it's potentially very confusing !
Down-load here.
https://www.dropbox.com/s/8pgyggulblig6 ... SOCKET.jpg
I think the new plugs/sockets available from SNGB for ?70 are an excellent copy, I'm really grateful that someone has bothered making them again, but unfortunately they copy all the faults of the originals such as a hopelessly weedy aluminium body to the car-side plug on the wiring harness, such that the ears that fold over the plug might as well be made from kitchen-foil.
This was on my car and I think it is an original one -
and this is the new one -
- where the ears are as soft as putty, and the plug won't stand being disconnected more than once.
The general machining of the pins is not very impressive, and the screw-threads for the little cross-screws is frankly awful - one of mine stripped as soon as its screw was tightened and I ended up fudging it by cutting an oversize thread, wherupon it then split. My fault, but didn't fancy waiting whilst I got it swapped for another that would have been just the same.
I would recommend this modification, which is tricky to achieve but makes it bullet-proof - no instructions, if you're capable of doing it then you can work it out ! There are just two places around the periphery where you can get a screw. I did a test on the old one to prove the principle -
then had a go on the new one -
It is essential that all the wires be twisted and tinned, then soaked in WD-40 upon assembly ; I even heat-shrank the outside to keep it all the screw-heads under compression. We motorcyclists end up quite OCD about corrosion/water-in-electrics etc
