Not sure there is anything I can do to change it though. Any thoughts or should I just leave it alone?
A truly skilled fabricator can move metal around with heat cycles if the metal is suitable. Don't know about the cage, but I've heard of heat and quench being done on lower wishbones. It could be made to work on the cage but not in-situ because the toe-in would be held rigid by the unchanged diff and inner pivots, as nothing outboard of them has any effect on toe. You'd need to do your cage tinkering (probably between the two pivot holes at the front to increase toe-in) and then re-shim the pivot blocks.rfs1957 wrote:By "blue-tipped-universal-adjusting-tool" I meant oxy-acetylene ........... they were heating them up in the middle and probably doing something clever with cold-water. Sounded voodoo but he swore you could watch the change and freeze it where you wanted, sounds hard to believe and I don't understand the metallurgy. Maybe it was 1st April after all.
Although toe in of one rear wheel cannot be adjusted in respect to the other, the IRS can by virtue of its flexible mounts be rotated relative to the body by changing the length of the trailing arms, which I think is what Rory is referring to.PeterCrespin wrote: It could be made to work on the cage but not in-situ because the toe-in would be held rigid by the unchanged diff and inner pivots
That's what I said about David's car in October Andrew. However, I don't recall reading his wheelbase measurements, which is the dead easy way to check out this option.abowie wrote:Although toe in of one rear wheel cannot be adjusted in respect to the other, the IRS can by virtue of its flexible mounts be rotated relative to the body.
Moeregaard wrote: The correct (factory) orientation of the large trailing-arm bushes has the holes sitting fore and aft. I have heard that mounting them 90-degees off will effectively reduce any rear-end steering tendencies.
