Indeedely doodely - that's why I said uprights :-)johnney wrote:Series 1 and 2 steering arms are not interchangeable the mounting hole centres are different.PeterCrespin wrote:There are different steering arms on S2 cars so maybe S2 uprights on an S1 car or vice versa might cause binding?
People sometimes swap XJ and E-type series around to get better brakes or stiffer stub axles etc. I doubt that's the issue here mind you but you never know. I've only ever used Jaguar racks so maybe the aftermarket inner ball joint nuts are an issue if binding occurs with standard length dampers. I assume this problem has never occurred on an unrestored car using the parts it left Browns Lane with (even if clapped out) and only shows up on rebuilt ones?
