Series 1 seat belt set up
#1 Series 1 seat belt set up
My 62 FHC does not have or has ever had seat belts. Rather late in the day as she is now fully painted and in the latter stages of building it up, it occurred to me that I should think about a set of seat belts. I see that in about 64 Jaguar added a boss under the rear side window to fix the shoulder strap but not sure what to do with my car. Presumably they were an option from new even in 62 . Can someone please enlighten me what to do or where to fix the belts please?
Well that didn't get you very far Andrew !
Mine being an OTS, this may not be much help on a Coup? but might just focus your mind on a couple of the issues ?
http://etypeuk.com/forum/viewtopic.php?p=36760#36760
Kind regards, Rory
Kind regards, Rory
hi Andrew
apologies, meant to reply days ago, but was distracted by xmas?.
these are pictures taken of my 63 FHC
is this what you were looking for??
let me know if you need more details
regards
Jonathan
regards
Jonathan
Thank you guys and apologies for only just noticing your replies. For some reason I never get notifications of replies so have to trawl though my posts to check.
I was wondering about how the belts fitted but have now discovered the boss under the side windows albeit its a different threaded item to your which i believe were fitted in late 63? and there are two bolts on the floor I gather. Think I should be ok now. Much appreciated
Service Bulletin Jan 1962:
JUST PERFECT DAVID. Where do you turn this stuff up? Many thanks for this.
Andrew
Andrew
A bit more info concerning threads etc:
