Whilst posting, I have a stone shield that I can't think where it goes and can't find a picture to help me (even though I took dozens). Can anyone place it?
Andrew
Andrew, your solution seems a bit extreme! Personally, I always release the lower ball joint and find that I can refit the torsion bar without any issues.skiday wrote:I would like to offer my solution for the problem of fitting the reaction plate. The problem being, as anyone who has done it will know, is that the torsion bar turns the two ends inward making it very difficult to insert the bolts that hold the torsion bar and reaction plate. The previous restorer's solution was to weld the torsion bar to the frame! I would like to suggest my solution, which I think is much better than his. I had extensions to the torsion bar welded on to hold the bars in the correct position. Now the two main bolts can slip in with no problem at all.
Andrew
etesteve3.8 wrote:I don?t see there is a problem or solution needed,only to understand how the torsion bar is adjusted so that it fits without use of large hammers etc.
The torsion bar has 24 splines on one end and 25 on the other giving endless vernier adjustment.With the top joint disconnected and the setting link in place then ------ in Skidays 1st picture the torsion bar needed moving towards the front of the car then rotating 1 spline at a time on the wishbone until the bolt holes on the reaction plate bracket line up with nothing having to be forced, stressed or welded .
Steve3.8
Not only that, but the aluminium brackets holding it on should be bare. Looks nice though. I don?t have a photo to prove it, but I think I?m sure that when I took it off, it was bare aluminium hence the silver. But this is not a '100 point concourse car' it just needs to look beautiful (to me). Thanks for the info though.PeterCrespin wrote:The air trumpet shield should be black Andrew.
1954Etype wrote:Andrew, your solution seems a bit extreme! Personally, I always release the lower ball joint and find that I can refit the torsion bar without any issues.skiday wrote:I would like to offer my solution for the problem of fitting the reaction plate. The problem being, as anyone who has done it will know, is that the torsion bar turns the two ends inward making it very difficult to insert the bolts that hold the torsion bar and reaction plate. The previous restorer's solution was to weld the torsion bar to the frame! I would like to suggest my solution, which I think is much better than his. I had extensions to the torsion bar welded on to hold the bars in the correct position. Now the two main bolts can slip in with no problem at all.
if I adopt this method to refit the reaction plate now the engine and box are all in, will I need to strap the suspension. I am just wondering whether I can do this without the setting link in place as I have the shocks all fitted up. I have had a cursory look at fitting the plate, and it is a well known not throwing itself in so to speak. It seems sensible to release the tension on the torsion bars but then what problems will this give me at the suspension end? Having been under the car for the best part of the afternoon, I would rather like to move onto something more enjoyable!
Andrew
Angus
Those who said my solution was OTT offered solutions that involved releasing either the top or bottom ball joints or releasing the torsion bar from its splinned holders. What was your solution?andrewh wrote:well, the reaction plate is now in but even with the car back on the suspension with the engine and box in I cannot get the top shock absorber to reach up further enough to go back in!! this is a pain of a job. Surely the weight of the engine should be enough to fit a shock absorber? Its not rocket science. The torsion bars are standard ( to my knowledge ) and they were set with the setting link in place, so by rights it should be back down to ride height. No bonnet of course, but you must be able to replace shock absorbers without the weight of the bonnet ?
