Motor out for the first time, looking to reset torsion-bars and get correct ride-height.
Have made up the bars with 452mm centres as substitutes for the front dampers as per factory manual, but can't drop the lower wishbones sufficiently before they foul on the picture frame.
They overlap the frame tubes by about 40 thou, so won't rotate any further, and I'm 20 or 30mm short of getting the 452mm links into place.
Same on both sides.
So what was put together incorrectly 25 years ago for this to happen, anyone got any ideas ?
