Front discs - keep or replace?
Markymark
#1 Front discs - keep or replace?
Post by Markymark » Mon Jan 05, 2015 7:46 pm
Hi Guys,
I've been lurking on this forum for a while now and have found it to be very useful.
Last year I imported a 69 OTS and I'm just cracking on with my list of winter jobs.
Whilst working on the front hubs I noticed that the discs look very old, thin and appear to have some edge chips. I think they should be replaced, but nothing was mentioned at the MOT, so wondered what you think?
I'm hoping you'll see some pics below....
Cheers,
David Oslo
Norway
Post by David Oslo » Mon Jan 05, 2015 7:55 pm
I vote for change. Peace of mind. Minor cost. Minor job (DIY).
David
S2 OTS '70 (arriving)
Post by christopher storey » Tue Jan 06, 2015 10:03 am
The discs are very cheap and to change them is the work of an afternoon at most. I would change them
PS I see you already have the hubs off - in that case it's perhaps 20 minutes a side to do
iani
Post by iani » Tue Jan 06, 2015 10:45 am
christopher storey wrote:The discs are very cheap and to change them is the work of an afternoon at most. I would change them
Unless the 'specialist' doing the work manages to shear a calliper mounting bolt resulting in some engineering being required. I took my chap 6hrs to change two discs, funnily enough that was the last piece of work I gave him.
Ian
E-type - TBC
1968 Triumph GT6 Mk1
Post by PeterCrespin » Tue Jan 06, 2015 2:25 pm
iani wrote:Unless the 'specialist' doing the work manages to shear a calliper mounting bolt resulting in some engineering being required. I took my chap 6hrs to change two discs, funnily enough that was the last piece of work I gave him.
Ian
The feeling may be mutual. I somehow doubt he purposely sheared off your bolt just to annoy you and charge you extra. In circumstancesz like this - which are extremely common on classic cars (especially in rust-prone climates) - traders typically under-charge. Often they do not recover their true hours, let alone aggravation. If you want by-the-book predictability then run a modern car.
I'm not saying the guy wasn't an idiot or a shyster, but I strongly suspect he was neither and it was all just par for the course. We sometimes forget things don't go according to plan. When you've worked on classic vehicles forty-odd years it's almost a bonus when it does...
Markymark
Post by Markymark » Tue Jan 06, 2015 2:50 pm
Thanks for the replies guys. I've ordered my new disks....
Red Kite
Post by Red Kite » Tue Jan 06, 2015 3:19 pm
Does anyone know what the "wire" in the middle of the S2 discs is for.
Also, is it possible to get replacements like that ?
Gerry.
S2 FHC 1R20003
jagman1970
Post by jagman1970 » Tue Jan 06, 2015 3:39 pm
I believe the wire is an anti-squeal ring. I bought 2 genuine Jaguar discs about 15 years ago and they were difficult to source then.
regards
Keith
Keith
1970 2+2 owned 40 years, 348TS
db7gtgrigio
Post by db7gtgrigio » Sat Jan 10, 2015 10:02 am
I replaced my S2 original discs 4 years ago as like the OP they had chips on the edges. Was unable to find original spec replacements with the anti squeal wire so I bought a pair of solid ones from SNGB which were surprising cheap 25 quid each from memory. Great performance and no squeal whatsoever, so I would say but new and don't worry
Chris, Sydney AUS
1969 4.2 FHC 1R20280
