Window Frames
jrevel
#1 Window Frames
Post by jrevel » Wed Feb 11, 2015 11:39 am
Just starting down the long road of restoring a series 2 FHC. The car has already been partly broken down (robbed for parts). There are a pair of door window frames. I have noted that they have no lower braces and most of the ones I have seen do have lower braces.
Is there a reason for this?
Thank you
Post by christopher storey » Wed Feb 11, 2015 6:42 pm
There should be a longitudinal strip which runs between the two legs. It is, IIRC, very shallow channel ( to stiffen it ) mounted with its wide dimension in the vertical plane, and its function is to stiffen the trapezoid shape of the frames as a whole
tinworm
Post by tinworm » Thu Feb 12, 2015 4:41 pm
This changed by series 2 production but only on the FHC's - the lower rail was deleted by Jaguar - it continued on with the OTS.
hope this helps Barrie
jrevel
Post by jrevel » Mon Feb 16, 2015 4:14 pm
Great and thank you for the feedback. Looks like I do have the right ones then.
dal2.0litrefrogeye
Post by dal2.0litrefrogeye » Wed Feb 18, 2015 1:15 pm
Hi Jason nice to see you posting , next time you come round have a look at mine for a comparison .
Its a way of life not a hobby
Darren . 64 4.2 modded 69 4.2
jrevel
Post by jrevel » Tue Feb 24, 2015 12:50 pm
Cheers Darren, will be up to see you again in two or three weeks. She has me fitting a new bathroom at the moment so the car is on hold!
