Salisbury 4hu Companion flange repair or replace?
smokey_m14
#1 Salisbury 4hu Companion flange repair or replace?
Post by smokey_m14 » Wed Feb 25, 2015 2:03 am
After closer inspection of my companion flange I noticed some minor pitting.
It's probably near impossible to see from this picture but it's there. I haven't been able to source a replacement being as it appears this part is discontinued so my only other option at this time is to take it to a crankshaft shop to have it welded up and machined back down.
jag68
Post by jag68 » Thu Feb 26, 2015 4:32 am
Take to a bearing shop and ask for a sleeve for it. These sleeves are made of a very thin steel hoop that fits over the area where the seal rubs, and are slightly undersize so they need to be forced on. It's set up to do this with a peel off flange that you push it on with, and a simple tool to push them on with. They come in many sizes. I've used them on this flange in the past. You may need to install it using a bearing retainer compound that the bearing shop can sell you.
Terry Sturgeon
1967 E Type coupe
1968 E Type OTS
2007 XKR
Durango2k
Post by Durango2k » Thu Feb 26, 2015 5:53 am
The name is "SpeediSleeve" iirc.
Carsten
smokey_m14
Post by smokey_m14 » Thu Feb 26, 2015 6:52 pm
jag68 wrote:Take to a bearing shop and ask for a sleeve for it. These sleeves are made of a very thin steel hoop that fits over the area where the seal rubs, and are slightly undersize so they need to be forced on. It's set up to do this with a peel off flange that you push it on with, and a simple tool to push them on with. They come in many sizes. I've used them on this flange in the past. You may need to install it using a bearing retainer compound that the bearing shop can sell you.
Terry Sturgeon
Durango2k wrote:The name is "SpeediSleeve" iirc.
Carsten
Thanks guys, I think thats the route I'll go. My best friend Bob swears by them up at the cement plant he was trying to explain these to me the other day but I couldn't picture it. That seems like a much more economical prospect than having it welded up and ground back down which was actually not to unreasonable he could weld it like a thrust surface and grind it down for about 65$-100$ when a brand new yoke NOS if you could find one was over 200$ but if their are no real advantages to welding and grinding it versus sleeving it them i'm definitely sleeving it
