Neil
All the LWB jacks I've seen are the same as the XJ jacks which use the same nipple to attach the jack pad to. Those cars have one circular jacking point nipple at each corner and the jacks have a circular hole not a u-shaped cutout like that example. It would work but would not be as secure. As David said, all SWB cantilever jacks had a square pad to fit over the single square location point half way along each sill. It's easy enough to convert the circular nipple cheap XJ jack to an expensive SWB jack by switching or modifying the pad on the end of the arm.tinworm wrote:Thats a 2+2 jack.
regards Barrie
