interior mirror components
rolando38
#1 interior mirror components
Post by rolando38 » Fri Jun 19, 2015 5:15 am
hello
I'v found my rear mirror broken when I bought the car, with the following compoents:
. casing split in 2 (now glued into one single piece)
. the glass mirror itself, with its nice triangular section
. a small part meant to switch the mirror between day/night position; thiis was broken and I found a supplier that can remake it with 3D laser capture and 3D printing
by the way if some of you also have this lever broken, I can help to remanufacture it (once the CAD file has been created, easier to mold or 3Dprint)
my question is: these 3 parts don't seem enough to have the mirror operating: are there any other samll parts ? spring ?
in particular there are 2 rectangular holes that seem ready to host a flat spring or something alike
any pics would be appreciated
thanks
2+2 1970
rolando38
Post by rolando38 » Wed Aug 12, 2015 9:31 am
in order to repair my broken rear mirror (not the mirror itself, but the plastic lever, at least), I requested my 3D printing supplier to make some
here is the result (he had to stick the 2 broken parts on a transparent plastic support, then scan it then print it) - I will do the painting
I fear some other parts are missing, though
any clue ?
2+2 1970
Henkie
Netherlands
Post by Henkie » Thu Aug 13, 2015 9:17 am
Hi Rolando,
No, you don?t need more parts! The lever works as a spring flipping the mirror glass.
My lever was also broken, but after I glued it together it is working again.
rolando38
Post by rolando38 » Thu Aug 13, 2015 1:11 pm
thanks Henkie !
there seems to be too much free play, though, without any other spring than the lever itself
does the glass stay firmly in poisition or does it wobble a bit ?
I might add a spring for improvement maybe
2+2 1970
