S2 Engine crankcase breather housing & pipe installation
Nickleback
#1 S2 Engine crankcase breather housing & pipe installation
Post by Nickleback » Sun Nov 29, 2015 7:20 am
I'm currently converting my 1970 S2 XKE to UK spec with SU's, however I cannot find the correct pictures, parts & numbers for the front engine crankcase breather & how it is installed correctly with SU's.
I do not think the breather assembly is available new anymore, therefore I need to source the correct used ones. :?:
Mike,
1970 S2 FHC 2R28165
Post by mgcjag » Sun Nov 29, 2015 9:46 am
Hi Mike...have a look here..parts 3-10.. is this what your after..the breather then connects to the air box that sits on top of the air filter.....personaly i have taken it to a catch tank Steve
http://www.sngbarratt.com/CatalogueProd ... 96&a=17242
Search ebay for jag breather, not sure what other models will fit
Nickleback
Post by Nickleback » Sun Nov 29, 2015 11:30 am
Thanks Steve, that's the complete setup I need but most of the parts are not available from SNGB, so it's a case of trying to find them.
Any suggestion apart from eBay ?
Mike,
1970 S2 FHC 2R28165
Post by mgcjag » Sun Nov 29, 2015 12:00 pm
Hi Mike...there are a few on ebay...you just need to find out if they fit what you have..also try Richard Smith also google e type engine breather for photoes
1954Etype
Post by 1954Etype » Sun Nov 29, 2015 12:40 pm
Mike, l have one now and am bidding on one on ebay.
Angus 67 FHC 1E33656
61 OTS 875047
Nickleback
Post by Nickleback » Sun Nov 29, 2015 1:35 pm
8),
Mike,
1970 S2 FHC 2R28165
