Il already had shown some signs of weakness, not always starting at each request.
Electrical supply seems to be OK otherwise, the battery is fully charged and the starter revs when switched on, so apparently the earth is OK.
I first thought of a worn fuel pump and was prepared to change it (I have a spare C19919R which seems to be an electronic model, my car is a 3.8 with positive earth).
Before changing it however, I checked the voltage between leads in the small electrical box inside the trunk when the ignition key is on: there seems to be some unstable voltage, neither 0 nor a good 12-13 volts.
Do you think the issue would be the pump itself or something else in the electrical supply of the pump?
Additionally, I am wondering how fuel leak tight will be the penetration of the electrical cable through the steel plate on the tank when I see the type of rubbers on each side of the plate of the new one compared to the screwing system of the current one. Should the current nut(s) be transferred on the new pump?
I have also observed that I shall empty at least partially the tank, because the plate seems to be positioned at a level under the current level of fuel in the tank: it started to leak when I unscrewed some bolts.
Should I also change the seal(s) of the steel plate or can I keep the current ones? Aalready the current seals seem to be not totally leak proof.
