Wider Wheels for the S1
MarkE
Topic author - Posts: 884
#1 Wider Wheels for the S1
Does anybody know the make / specification of wider wheels for the S1 E Type? I?m after something that fills the arches, doesn?t foul the bumpstops, has stainless spokes and enable tubeless tyres to be used. And just as important, what make and size of tyre works with these wheels?
I?ve seen a few S1s with bigger wheels (specifically Eagle E Types) and for me they enhance the look of the S1 by getting rid of the railway carriage look!
Thanks?Mark
Thanks?Mark
harryetype
Hi Mark
I think the car in the picture might have had the bump stops removed.
I sometimes fit 6" triple laced wires from MWS, these have stainless steel spokes and ar tubeless. You do however have to remove the bump stops.
The car I have nearly finished restoring has got 6" wires with a slight rim amd I have gone 225/60 15's although I usually fit 205/60 15's
On the whole I'd agree that a 6" rim with perhaps a 205 or 225 does look better but for my money an E Type just doesn't feel as nice on wide modern tyres - I've tried (If I had 350bhp it might be a different story).
I feel much more at home with my tall skinny tyres where you use the application of power to overcome the initial understeer. Far nicer than just pulling harder on the steering wheel of something that has far more grip than it was designed for.
Each to their own though but be aware that changing the tyres does more than just change the look.
Andy
Andy
1966 2+2 MOD Conversion
MarkE
Hi Andy
I think I know what you mean. My other passion is the Elan, and they are very sensitive to tyre size regarding feel and drivability. It?s pointless putting on anything other than the original size unless it?s going on the track, and a bigger tyre really does ruin the delicate feel of the car.
I don?t know, but I would have thought that the E, being quite a heavy car, wouldn?t show up the difference quite so much. Certainly my S3 feels fine with its standard 5.5 rims, but it?s much more of a tourer than the S1, and of course has power steering?very dead / light power steering!
I?m not really after improving the ultimate grip; it really is about the aesthetics. For me, the railway carriage appearance from the front or the back has always let down the overall balance / look of the car. It was the first thing I noticed when I first clapped eyes on an E Type in the early 60s! Well, probably not quite the first thing.
Another thing to discuss when we meet up, Harry. And thanks for your spec on the wheel / tyre. What happens if you hit a big bump with no bump stops??!!
Car-Nut
Two questions
1) what are bump stops -sorry if its obvious but I dont know
2) any chance of of uplading a rear veiw picture of your project car harry with the triple spoke 6" on please
Another vote for MWS wheels - an excellent product. http://www.mwsint.com/FitmentGuide/Disp ... rYear=1964
I run Pirelli P6000 205/65's 15" on MWS Competition 6" wires and they perform well unlike the Yokohamas I had on previously - great in the dry, lethal in the wet! MWS XW5745C/3 on the car and XW472C/3 (5") as a spare. The 6" wheel cannot be used as a spare as it will not fit in the wheel well, something many people overlook until they try to put the floor boards back! Rear bump stops have to be removed otherwise they will foul the wheel. Ideally you should fit bump stops to the shock absorbers to compensate otherwise you will have lots of grounding on uneven road surface as I can testify from personal experience.
The 6.5" wires look very good but I would worry about clearance if fitted with 225 tyres. You could also consider going to 16" wire wheels which look fantastic on a V12 with its wider arches but not I am not sure about them on an S1. Worth investigating though.
Finally you may need to consider having your speedo re-calibrated to compensate for the change and ensure the tyres have the correct speed rating - V for our cars. Fitting tyres with the wrong speed rating can invalidate your insurance regardless of what speed you were travelling in the event of an accident.
David
David
CliveCar-Nut wrote:Two questions
1) what are bump stops -sorry if its obvious but I dont know![]()
Bump stops are O shaped pieces of rubber bonded to a metal plate. They bolt on to the bodywork in the rear wheel arch and act as stops against the hubs before the limit of suspension travel is reached (do an eBay search on 'E-Type bump' and you should see an example, they are regularly listed). Stops the car grounding but they have to be removed when fitting the wider wheels. Some people have been able to cut them in half longitudinally so they still work. Ideally they should be replaced with rubber bump stops on the shock absorber shafts - something I really must get round to.
I will take a photo of my car from the rear tomorrow so you can see the 'look' of the 6" wires.
David
Car-Nut
#9
If you play with an Elan you will be well aware of the effect of changing tyre sizes. The E is not as finely balanced as an Elan but the same rules apply even if to a lesser extent.
The S3 is an altogether different kettle of fish. Mind you I could hang the tail of my much missed XJR-S out but it was hardly a case of finely balancing it on the throttle.
Andy
Andy
MarkE
#10
6 litre XJR-s I hope Andy. I'm selling one in a month or so as part of the E Type re-focus :D . Cheep cheep!
I never could get the hang of 'sideways' in an auto...it seems to lack a certain amount of control And the old XJR-s with all its 'tourques' (as JC puts it) can and does catch you out in the wet quite often. Cracking car though...Jaguar's best from the 80s, and one of the finest form the 70s and 90s too come to think of it.
Don't tempt me Mark. I'd love to ditch the "family" Range Rover and replace it with another XJR-S but my wife finds it easier to be nosey in the RR. You can see right into people's front rooms. All you can see from an XJR-S is the letterbox.
Sideways XJS - Knock it down from D to 2 and throw it at a bend and use the weight shift to break the rear away.
Obviously I'd never dream of doing such silly things on the road.
The XJS is a truly great car. There are still very few cars at any price that I'd rather drive any distance in.
Andy
Andy
Great thread!
Series1 4.2 roadster and this is one expensive decision I'm wrestling with.
6" is definitly an improved look and $2,000 worth of Dayton wheels.
My 5" original need a complete rechroming an almost equal cost.
Losing the feel is a big negative, but to feel it first hand one must experiance it.
Wish I could find two cars to feel the differance before I shell out the cash.
I never see 6" Daytons for sale on eBay just the old scruffy 5" wheels. Maybe after an expense such as this you live with it.
How about buying two and feel the differance alternating the 6' from the front then the rear for feel.
Tyers and wheels would not have a return policy?
Hello, just joined the forum. Looks good and very informative so far!
I'm just about to replace 4 Dunlop 185 tyres on 5" wire wheels. Does anyone have experience of fitting Pirelii P4000 or similar 205 tyres to these standard size wheels? I want the wider look without the expense of 6" wheels if this is safe and possible! Any views?
The tables I have show that a 5.5 - 7" rim is recommend for a 205 tyre.
So your 5" are just a bit too small.
When it comes to tyres I can only suggest that you stick to the manufacturers suggestions.
A chat with somebody like Longstone Tyres would put you on the right course.
Andy
Andy
I agree with Andyp, stick with 185 tyres on the 5" wires. Alternative is to go to 6" wheels with the Verdestein 185's. The wider wheel increases the stiffness of the tyre sidewalls giving better roll resistance and improving handling.
If you start changing to lower profile tyres you will most certainly need to recalibrate the speedometer and consider you will be lowering the overall gearing. Not a problem if you are running a 3.07 diff I suppose but could cause a noticeable change if you are running 3.31 or 3.54.
To give you an idea a 205/65/15" tyre has a diameter of 647mm and a rolling circumference of 1950mm. Compare this to your current tyres and you will get an indication of how much the gearing will change. A typical 185 tyre has a diameter of 675mm and a circumference of 2035mm - about 4.5% more.
David
David
I was thinking of a 205/70ZR15 Pirelli P4000 which has a diameter of 669mm. Not too far from original. I have been told these fit 5" wheels with ok results but have also read that it's not recommended (4th question down on http://www.classicjaguar.com/wheels.html). My call I guess.
Thanks for your replies, I'll give Longstone tyres a call!
Go for the Pirelli P6000's - far and away better than the P4000's which are a cheap economy tyre designed for small family runabouts. Handling is dismal on an E-Type.
David
David
I spoke to Simon at Longstone tyres today and he agrees that 205s on 5" wheels is possible but not practical. Hard to fit onto car, extra strain on sidewall and high wear on crown of tyre, not to mention much heavier steering and a changed feel to the car. He said 205s on 6" wheels a much better solution. New wheels then!
What 205 tyres did he recommend?
205/70VR15 Michelin XWX listed at ?204.50 but offering 5% discount off that.
Said they're good performance tyres and look good on the car. As for P4000, he shares same view as you, namely a bad idea despite ?110 price. Good to know as I'd been recommended these and saw a few E Types fitted with them at Goodwood Revival last year. I'm probably going to go for MWS stainless 6" wheels. Longstone will supply wheels with tyres fitted and balanced with no increase to MWS own wheel price! Sounds fair to me.
