vee eight
Post
by vee eight » Sun Feb 28, 2016 9:21 pm
Hi All,
I was changing the gear box oil today and noticed that I might be missing a flywheel cover plate.
Firstly should there be one there and secondly if there should would I be able to fit a new one with the engine /gearbox in the car.
Please see attached photos
Thanks Phil
Phil[/img]
1967 Series 1 E Type Roadster - 1968 TR5 - 1966 Corvette Stingray Convertible
1954Etype
- Moderator
Post
by 1954Etype » Sun Feb 28, 2016 9:42 pm
Yes. Held on with 4 1/4" unc bolts. Available from SNG.
Angus 67 FHC 1E33656
61 OTS 875047
tim wood
Post
by tim wood » Sun Feb 28, 2016 9:45 pm
Often available at Stonleigh. Brought mine for a tenner.
Definitely UNC bolts.
vee eight
Post
by vee eight » Sun Feb 28, 2016 11:33 pm
1954Etype wrote:Yes. Held on with 4 1/4" unc bolts. Available from SNG.
Thanks Angus
Are you saying that I will be able to fit the plate from under the car without having to take anything apart.
Cheers Phil
Post
by abowie » Mon Feb 29, 2016 3:04 am
I leave mine off normally.
1954Etype
- Moderator
Post
by 1954Etype » Mon Feb 29, 2016 7:33 am
Yes, Phil. Fits no problem. We like to fit them as a stone (or similar) finding its way in there could be nasty!
61 OTS 875047
