Dumbo Question time. Rear Brakes
andrewh
#1 Dumbo Question time. Rear Brakes
Post by andrewh » Thu Apr 07, 2016 6:43 pm
I am just rebuilding an IRS from a LHD car going to RHD. Given the different location of the pedal box and servo/master cylinder, do I need to move the T piece on the IRS to the opposite side to enable to brake pipe to run down the RH chassis leg? I cannot recall what its routing was when I stripped the car. Also, is it easier to build the handbrake assembly onto the callipers before putting in the diff or afterwards? Now I have done that before a couple of years ago but cannot for the life of me recall which way around I did it. I suspect it may need to be fitted after the diff is in?
thanks Andrew
1962 3.8 Series One FHC
1954Etype
Post by 1954Etype » Thu Apr 07, 2016 7:12 pm
Yes. Tee piece follows the side of the servo. Fuel line and brake pipe clip is combined.
Angus 67 FHC 1E33656
61 OTS 875047
andrewh
Post by andrewh » Thu Apr 07, 2016 8:49 pm
thank you for that. Seems obvious but worth asking. Any thoughts on the handbrake? Not sure the manual makes that clear.
1954Etype
Post by 1954Etype » Thu Apr 07, 2016 10:33 pm
No change as handbrake doesnt move for lh or rh. Come on Andrew, keep up at the back!
61 OTS 875047
Post by mgcjag » Thu Apr 07, 2016 10:46 pm
Hi Andrew.....assemble the brakes and handbrake mechanism onto the diff...then fit it in the cage, then fit the actuator ......
andrewh
Post by andrewh » Fri Apr 08, 2016 5:59 am
thanks chaps, very helpful. :D
