Right hand drive conversion
Dave Maddock
#1 Right hand drive conversion
Post by Dave Maddock » Sat May 07, 2016 7:04 pm
I have a 1973 series 3 OTS LHD and want to convert it to RHD.
I am in Cheshire and am looking for someone to do it for me, ideally someone who has done it before and go all the T Shirts to avoid surprises.
Does the engine need to come out to do this? Plus it has air con, is this a problem for he conversion?
Any ideas? Any help much appreciated.
Post by Heuer » Sat May 07, 2016 7:53 pm
Suggest you go to the Forum Knowledge Base where you will find a full set of articles on LHD to RHD conversion.
Dave Maddock
Post by Dave Maddock » Sat May 07, 2016 7:57 pm
Hi David.
Thanks for getting back, I will search for the articles, i am new to e types and the forum.
Tell you what though, what a joy the car is.
MarekH
Post by MarekH » Sat May 07, 2016 8:40 pm
There was a thread recently about the power steering rack conversion using a kit that had been listed via ebay.
The aircon will have to go unless you want to fabricate a new housing as it will foul the steering column on the rh side.
Dave Maddock
Post by Dave Maddock » Sat May 07, 2016 8:55 pm
Thanks Marek
Do you know of anyone who could do this for me?
Bob.
Post by Bob. » Sat May 07, 2016 9:14 pm
You don't have to take the engine out but unfortunately you cannot convert to RHD and keep the original aircon since its fan is integral with the unit in the dash and is in the way of a RHD steering column. Jaguar did not make any RHD S3s with aircon so there isn't a Jaguar RHD A/C unit. Some specialists like Clayton Classics have come up with new systems but they won't be cheap.
RHD power steering units are becoming hard to find and if you are going to one of the established specialists for the LHD to RHD conversion expect budget prices of ?5k to ?7k plus VAT.
Bob
'71 S3
Bob.
Post by Bob. » Sat May 07, 2016 9:16 pm
Oops - I was a bit slow there!
M&C Wilkinson - Doncaster
XK Engineering - Coventry
CMC - Bridgenorth
E-type UK- Kent
Angus Moss - posts on this forum
There are others
Bob
'71 S3
Dave Maddock
Post by Dave Maddock » Sat May 07, 2016 9:36 pm
Many thanks
Post by Heuer » Sat May 07, 2016 10:01 pm
Have a look here: viewtopic.php?t=700 and scroll down.
madjack4
Post by madjack4 » Sat May 07, 2016 10:14 pm
Hi Dave
I have converted my s3 roadster over from left to right hand drive i run my own garage in wakefield west yorkshire i would be happy to quote you on the conversion you have to remove the aircon fit new lower dash panels and centre console the column will change to the other side but it is the wrong way round so a right hand drive column is needed if u want a proper looking job call me on 07778807739 if you are interested
Regards Rob
Dave Maddock
Post by Dave Maddock » Sun May 08, 2016 3:39 pm
Hi Rob.
I will ring you on Monday or Tuesday depending on work load.
Is it best to ring during the day or evening?
madjack4
Post by madjack4 » Sun May 08, 2016 9:22 pm
Hi Dave
Anytime that is best for you
Regards Rob
madjack4
Post by madjack4 » Tue May 10, 2016 8:08 pm
Hi Dave
Checked availability of parts and worked out a price
Regards Rob
angelw
#14 Re: Right hand drive conversion
Post by angelw » Fri May 13, 2016 8:29 am
Dave Maddock wrote:I have a 1973 series 3 OTS LHD and want to convert it to RHD.
Hello Dave,
The only part of the PAS Steering Rack that is not truly ambidextrous is the aluminium housing that the Pinion Tower assembles to. Even the LHD Pinion Tower can be used, but a custom set of tubing is required. Instead of the connection points on the Pinion Tower pointing towards 5 o'clock (viewed from sitting in the RH seat), they will point towards 2 o'clock when the Pinion Tower takes on its new orientation. Using the LHD Pinion Tower and custom tubing is not noticeable and you really have to go looking to pick it.
If, however, you want everything to be exactly right, a Pinion Tower from a LHD Series 1 XJ6 is exactly the same as a RHD S3 E Type PAS Pinion Tower.
The die casting that incorporates the Ignition Switch needs to be turned around on the Steering Column so the the Ignition Switch is toward the centre of the car and the Turn Indicator stalk is toward the outside (Right side of Steering Column). This needs to be done so that the shape of the plastic housing that incorporates the Turn Indicator Stalk fits the curve in the bottom edge of the Dashboard panel. I have done many complete conversions and have supplied even more kits to those withing to do the job themselves. If you care to email me at the following address, I can give you all the information you require to complete the job with the minimum of fuss.
bill.angel@bigpond.com
With regards to the aluminium housing that the Pinion Tower attaches to, I manufacture these in both Left and Right Hand Drive configuration. Outwardly they are indistinguishable from the original equipment (they're an aluminum alloy casting), but the internal machining is superior to that of the original part. I can supply any part you may want from just the finished machined aluminium housing, to a complete, ready to install RHD PAS rack assembly.
Davj
#15 Re: Right hand drive conversion
Post by Davj » Sat Apr 02, 2022 11:40 am
Hi Dave, did you succeed in changing to rhd, am in the same boat, any advice much apppreciated, davj
Dave from Swansea. Awaiting arrival of a Series 3 1973 left hand drive from California. Had a Series 3 20 years ago,always regretted it being sold but circumstances at the time
lowact
#16 Re: Right hand drive conversion
Post by lowact » Sat Apr 02, 2022 12:29 pm
Hello Davj, you might need to clarify. Is the question about how to do it or is it whether or not he found someone to do it for him?
Davj
#17 Re: Right hand drive conversion
Post by Davj » Sat Apr 02, 2022 4:46 pm
I have just joined the forum,I was wondering if he was successful in converting and if he had someone to do it. beyond my limited capabilities. I have a lhd Series 3 arriving from USA in 2 weeks. I had a Series 3 rhd from South Africa in the late 1990s ,unfortunately I sold it. It turned into a kitchen for my ex wife
#18 Re: Right hand drive conversion
Post by Gfhug » Sat Apr 02, 2022 5:39 pm
Davj, if you look in the knowledge section there’s a complete set of articles for conversion LHD to RHD. Although based on the six cylinder cars most will apply to the V12. Read through and see if you can manage that sort of work. If not start finding reputable companies to do the work. Beware a reputable company will have a waiting list and don’t go chasing after any old back street mechanic to do the work. You’ll get what you pay for.
Please also include your name and car type in your signature. It’s much more pleasant to address you by your name and if we know what car you have it’s easier to reply appropriately.
Good luck
Davj
#19 Re: Right hand drive conversion
Post by Davj » Sat Apr 02, 2022 9:13 pm
Thanks for the advice
PerryGarrod
#20 Re: Right hand drive conversion
Post by PerryGarrod » Wed Aug 07, 2024 7:39 am
Dave, did you do the conversion?
If so, don’t suppose you have any redundant LHD air con parts?
Would be very interested to hear from you/anyone with same.
KR
Perry
