We've been trying to convert my 4.2 S1 E-type to an electronic ignition. We've put the Pertronix unit in but want to double check the wiring is correct with some owners.
Before
We had 2 wires coming from the coil. The B/W wire went to distributor from the positive terminal of the coil. There was also a White wire that came from the positive terminal but we aren't sure where this goes. We think it might be for the ignition switch. Can someone confirm.
After
We now have 3 wires connected to the coil. We have a Red wire from positive coil terminal to the distributor and a Black wire from negative to the distributor. We also have the original White wire that we think goes to the ignition from the negative terminal.
When converting the ignition the instructions for the new system expected there to be a wire from the negative terminal of the coil to the distributor. Instead ours was connected to the positive side of the coil. Why would this be? Is it something the previous owner had connected wrongly?
Finally can someone confirm that our new wiring is correct and that there should be 3 wires connected to the coil?
Trev
