christopher storey wrote:I think we have been here before : I can conceive of no possible way in which end float on any gearbox shaft could result in crankshaft breakage
Have to agree with you, albeit
sans evidence I'm ill-qualified to be too dogmatic. It appears to be in the same league as "Articulated lorry destroyed by head-on crash with dog."
No? Me neither.
At least we can be certain the noise cannot be the clutch release bearing.It happens cruising in fifth and stops when the clutch is depressed, which is exactly the opposite scenario.
The stabiliser is either correctly adjusted or not. Check, adjust if necessary, thrn eliminate from enquiries.
The Elite mount is two bobbins, rather like the 3.8 mount. If they are still good anex neither they nor the engine mounts have collapsed or come apart, the movement is what it is.
The noisy gears are something different, but with no foam or console, indirect fifth is bound to sound noisier than 1:1 4th gear. On my Getrag only 2nd and 4th were what I'd call 'refined' and idle noise was high. Heavier or synthetic lube may help but Elite must be allowed to specify their own grade if they are to offer warranty cover.
