Can I take it that this bracket/plate at the foot of the rear-view mirror bar is an "addition" ? I think we were in the getting-divorced-gotta-finish-the-car-and-flog-it-mode at this point. Any suggestions about repairing this ? Some kind of bar from L to R secured in those holes near the corners ? And what is at the bottom of the threaded-bar normally - see the slot and some glued-on nut.
Are the black trim triangles behind each door pillar secured just by glue at the lower ends ? Top they're held by the chrome caps ? Lower left is also sandwiched by the grab-handle ? But lower right is glue only ?
The lower windscreen trim strip has holes at either end but no corresponding hole or even opportunity to screw into anything that I can see - is this strip just held in by the lower curve of the chrome side-plates ?
I'm intending to change the complete front-of-doors rubber seals, are these sold as uppers and lowers (the upper being quite a complex shape) or are they joined together when you buy them ? And what is the best glue for this - the PO used Evostick and it's now horribly yellow.
Is now the time to change all the windscreen washer-jet piping, and if so how the ---- do you get your hand inside the box-section ?!
All and any advice / comments / jibes most welcome.
