I'm re-using my old rear springs as recommended by many on the Forum. I ordered new Boge rear shocks from SNGB (as I think one of my originals is leaking), plus the top rings C19027 plus spring seats C19820, as advised by them. The spring seats C19820 are in fact out of stock so I plan to re-use the originals. The split collet comes included with the shock.
The bottom end all looks fine.
But it's not at all clear to me how the spring will locate at the top. The top ring C19027 doesn't locate onto the shock in any way, and even if it did, it would introduce extra packing thickness between spring and shock that didn't exist before. If I leave it out, the length will be OK but the spring isn't positively located at the top, which sounds like a very bad idea. What am I missing here?
