Trimming panels Staple gun
#1 Trimming panels Staple gun
Post by mgcjag » Mon Jul 11, 2016 8:42 am
Hi All.....will be starting retrim of interior soon......Im looking for a staple gun to use......cant find an electric one that uses 4mm staples which i think are the size needed for door panels etc so they dont go right through the board......what have you used.....there are manual ones available that take 4mm are they any good ?.....and have found an air one......I have looked at the spec for quite a few with the staple size showing as starting at 8mm....can you put a 4mm in them? Thanks Steve
kingzetts
#2 Re: Trimming panels Staple gun
Post by kingzetts » Mon Jul 11, 2016 4:54 pm
Steve,
I have used manual staple guns for years and they are good for trim work. I have tried an air stapler but find this rather fierce for use on delicate trim boards, so reverted to manual. Have never used an electric stapler but suspect it too might be a bit harsh for trim. Can't advise on brands as I bought mine donkeys years ago in the USA.
John '62 S1 OTS (now sold)
#3 Re: Trimming panels Staple gun
Post by mgcjag » Mon Jul 11, 2016 5:47 pm
Thanks John....there are plenty of hand ones for 4mm....if you found them ok for the job thats good for me all tne best... Steve
kingzetts
#4 Re: Trimming panels Staple gun
Post by kingzetts » Mon Jul 11, 2016 8:19 pm
Steve,
I also found a small hammer (what my old dad would have called a toffee hammer or tack hammer) was useful for occasions when the staple stood a little proud if I didn't press down firmly enough on the gun....
caveman
#5 Re: Trimming panels Staple gun
Post by caveman » Thu Jul 14, 2016 6:10 pm
Hi Steve,
I used a Bosch PTK 14 Duotac for my seat restoration. Perfect but starts at 6mm for staples unfortunately.
I see they do a battery operated one now with 4mm - 10mm staples, PTK 3.6LI (approx £50).
1965 S1 4.2 FHC (early)
:wavegreatbritain:
#6 Re: Trimming panels Staple gun
Post by mgcjag » Fri Jul 22, 2016 12:40 pm
Just a quick uodate...purchased a Tackwise Z1-53 hand operated staple gun......4mm staples also available from tackwise......tried it out and works ok http://www.ebay.co.uk/itm/391505346719? ... EBIDX%3AIT
