Fan Motor Relay Location
rojakilian
#1 Fan Motor Relay Location
Post by rojakilian » Tue Jul 05, 2016 5:52 pm
i forgot to mention that the car is a 4.2 series 1.
Best regards
Robert
#2 Re: Fan Motor Relais Location
Post by mgcjag » Tue Jul 05, 2016 6:08 pm
Hi Robert...should be on a bracket bolted on top/front of the picture frame
Polse7317
#3 Re: Fan Motor Relais Location
Post by Polse7317 » Wed Jul 06, 2016 5:17 am
I bolted it there :
Polse7317
#4 Re: Fan Motor Relais Location
Post by Polse7317 » Wed Jul 06, 2016 6:41 am
Here is :
andrewh
#5 Re: Fan Motor Relais Location
Post by andrewh » Wed Jul 06, 2016 9:05 am
I cannot be 100% sure, but was the relay only on the 3.8 early cars? I may have that wrong but I recall when ordering my new wiring loom I was asked if it had the relay or not? Assuming it was not on later 3.8s did they delete it from 4.2s as well?
1962 3.8 Series One FHC
#6 Re: Fan Motor Relais Location
Post by mgcjag » Wed Jul 06, 2016 9:12 am
andrewh
#7 Re: Fan Motor Relais Location
Post by andrewh » Wed Jul 06, 2016 12:06 pm
that of course is a 4.2 series 2 with the twin fans I assume. Cannot see a reference to a fan relay in the series one 4.2 parts book though?
paulsco
#8 Re: Fan Motor Relais Location
Post by paulsco » Wed Jul 06, 2016 12:53 pm
There is no fan relay on the Series One 4.2.
#9 Re: Fan Motor Relais Location
Post by mgcjag » Wed Jul 06, 2016 1:35 pm
Hi Andrew....yes you are correct..there is no fan reley on the S1 4.2 diagram in the knowledge base
rojakilian
#10 Re: Fan Motor Relais Location
Post by rojakilian » Sat Jul 09, 2016 5:08 pm
Hello again from Germany,
thanks a lot for your replies - i saw it now, there is, for what reason ever, no fan relay fitted in the ser.1 4.2. That is strange, because the 3.8 got one and the later series 1.5 and 2 got one again....the (new) loom i have is from a series 2 i guess ( i am puzzling a kind of "bitsa"car together from a mountain of new and used parts....) Its awful sometimes, even if it may now at least financially makes sense, i will never do it again...
Best regards
Robert
1954Etype
#11 Re: Fan Motor Relay Location
Post by 1954Etype » Mon Jul 18, 2016 8:57 pm
It is a good idea to fit a relay.
Angus 67 FHC 1E33656
61 OTS 875047
