Hi does anyone know where I can get a new replacement windscreen for a S3 2+2, The local autoglass agent has had an order with SNG Barrett for about Six months now without success and I am losing patience with them. Also I understand there are various tinted versions available, mine is a clear version, were tinted windscreens available as standard, has anyone fitted a tinted version to replace their original clear one and if so does this look ok?
Help I need a Replacement Windscreen for S3 2+2
#1 Help I need a Replacement Windscreen for S3 2+2
1972 S3 2+2 with HE V12
#2 Re: Help I need a Replacement Windscreen for S3 2+2
Hi Dave......try contacting Pilkington......they are reproducing E windscreans......also CMC in Bridgenorth who may help
viewtopic.php?f=2&t=8029&hilit=Pilkington
http://www.classic-motor-cars.co.uk
#3 Re: Help I need a Replacement Windscreen for S3 2+2
Thanks I will give both of them a go
#4 Re: Help I need a Replacement Windscreen for S3 2+2
I recently had a new screen from Pilkington for my OTS. Great service, all the tint and other options your could wish for and expedited delivery for a small surcharge. It fitted easily and best of all the top no longer leaks in the rain.
Adrian Turner
S3 OTS & FHC
S1 FHC
XK140 FHC
S3 OTS & FHC
S1 FHC
XK140 FHC
#5 Re: Help I need a Replacement Windscreen for S3 2+2
My replacement screen has finally arrived and been fitted without any issues, the chrome side finishers seem to be a tight fit but my question is should they be glued in place or not? On the old screen they were glued but the fitter said he did n't think it was necessary with the new screen as the fit was ok without, were they glued in when they came off the Jag production line?
#6 Re: Help I need a Replacement Windscreen for S3 2+2
Hi Dave good news you have the screen in...for info where did you get it and who fitted it....thanks
Ps re the finishets dont know how they left the factory....but think most glue then on..Sikaflex
#7 Re: Help I need a Replacement Windscreen for S3 2+2
Thanks Steve, It finally came from SNG Barratts (although it took about 6months) the screen has triplex stamp and was fitted by the local autoglass agent. They said the screen went in without any issues. To be honest the fit looks better than the previous screen.
