I know the official one is the J6118..but is there a more readily available type I could buy ...advice please..not sure what type to choose
Many thanks
Jonathan
Which valve spring compressor
#1 Which valve spring compressor
#2 Re: Which valve spring compressor
I just use a large, deep socket and a mallet. Couple of good hits and the retainers come out.
Similarly there's a tool a bit like a punch that you use to put the retainers in. Tool
I have not found a traditional C clamp compressor that fits.
Interestingly the tool seems to come apart to allow retainer removal too; never knew that
#3 Re: Which valve spring compressor
Hi Jonathan,
Do you own a 'normal' valve spring compressor? If so, I made up an adapter out of an old box spanner. Not pretty, but it worked a treat:
There are a couple of other things you may want to consider - as per the picture, a set of bucket hold-down plates and the fitting of inlet valve stem oil seals. You also need to modify the valve spring seats and valve collets or just buy new.
Let me know if you want to borrow the adapter and also the actual compressor.
Cheers.
Cheers.
62 3.8 FHC
91 Porsche 928GT
62 3.8 FHC
91 Porsche 928GT
#4 Re: Which valve spring compressor
Thanks guys...Simon...the offer of borrowing sounds perfect...I'll be in touch :)
