Chris,
Thanks for the super quick response. I am a bit clearer now thanks ! So there is a different larger filter system on the earlier XJ6 which involves the drum and paper filter you mention. I was unaware of this, but makes sense looking at this filter head with the sealing surface diameter outside the 4 mounting holes.
Many thanks for the offer of this larger drum, but although I will run this past my friend, I agree with you that this would be both non-standard and a bit of a pain with clearance. Being an ex-US car he has obtained, I would assume that a previous owner has fitted this later "modification" and I would suggest he looks for an earlier Series 1 filter head and canister which I assume would have been the "standard" fitment on these Series 2.
This is a spare Series 1 Oil FIlter Head that I also have - and now he will be badgering me for it ! - and the sealing surface of the Oil Filter can thin profile seal option, (rather than the other thicker seal also supplied with the filter), within the four mounting holes can be seen. I agree with you about the different gasket profiles and have heard about this before. I attach the photos of the Series 1 Oil Filter Head for others information and to compare these three different gaskets.
Many thanks again and hopefully this will be of use to others.
regards,
