abowie wrote:JagWaugh wrote:
I made a ball mill for tumble cleaning and polishing small parts. .
That looks good. i hate polishing the carby bells.
24h in the ceramic media will get them clean, with a smooth surface about the same as original. You can get a higher polish with walnut shell and polish (Rouge), but that will take about 48 hours.
See how the bells are fitted together? That keeps the media out of the bells.
If you are going to do it you need to find some way to stop the media from getting into any openings. I use plastic tubing, cable ties or whatever. The ceramic media can work itself into an opening and be buggerme difficult to get back out.
The walnut will come out with a bit of poking and blowing out with compressed air.
It takes a while to develop a feel for how many parts to put in a charge. I've been using tumble polishing on clock parts for years. You can put even the most delicate parts in and just ignore it for a day, when you take them out they will be clean down to any corner that the geometry of the media can reach, but there will be almost zero dimensional change. There is a whole host of media available (google tumble polish media). The bucket turns at about 40 rpm, because of the tilt the lid does not need to seal watertite.
I run a cleaning cycle with water, soap and a bit of ammonia. When you take a charge out you have to wash the parts immediately, if you let the smut dry on the surface it can be almost impossible to get it clean again without retumbling - the dirt gets ground so fine that it approaches something like an ink.
The nice thing about the ball mill is you just ignore it while it is doing it's thing.
