Door gaps
Bernie2015
#1 Door gaps
Post by Bernie2015 » Thu Mar 30, 2017 12:07 pm
Hi All,
can anyone offer some advice on how to improve this situation with both doors (Please see photos).
The upper and lopwer photos were taken with the doors closed showing large gaps at top front but flush with car at rear. Also starting to lose a bit of paint where it is binding on the frame - any suggestions welcome.
Bernie 1966 S1 OTS
#2 Re: Door gaps
Post by mgcjag » Thu Mar 30, 2017 1:27 pm
Hi Bernie.....you can adjust the doors....requires the hinges moveing....these doors are heavy and on a 2+2 that area is always difficult to get to look correct....also dosnt help if tne doors have been ever been re skinned....you can try yourself but might be earier to get a body shop to look at it.....mask up all the edges becaus its very easy to damage even more paint
Bernie2015
#3 Re: Door gaps
Post by Bernie2015 » Fri Mar 31, 2017 8:03 am
Many thanks Steve will probably get a body place to do it
Bernie 1966 S1 OTS
1954Etype
#4 Re: Door gaps
Post by 1954Etype » Sat Apr 01, 2017 7:44 am
Before you go to the body shop, make sure you have minimal play in the door hinges. If they are worn (and the 2+2 hinges wear quickly once they start to go) there is no point trying to set them up.
Hinges can be re-pinned.
Angus 67 FHC 1E33656
61 OTS 875047
Bernie2015
#5 Re: Door gaps
Post by Bernie2015 » Sun Apr 02, 2017 6:22 am
Hi Angus checked it and no movement but thanks for the advice
Bernie 1966 S1 OTS
tim wood
#6 Re: Door gaps
Post by tim wood » Sun Apr 02, 2017 4:14 pm
Hi Angus, do you have a contact who can repin these?
Tim
#7 Re: Door gaps
Post by mgcjag » Sun Apr 02, 2017 5:09 pm
1954Etype
#8 Re: Door gaps
Post by 1954Etype » Sun Apr 02, 2017 5:31 pm
Hi Tim, if you can't do them yorself using the article Steve posted, we can get them done for you. Let me know off line if you are interested. Angus
61 OTS 875047
