Downpipe sealing ring/o ring removal
TrevS
#21 Re: Downpipe sealing ring/o ring removal
Post by TrevS » Sat May 20, 2017 8:31 am
mgcjag wrote:Hi Trevor...dont be put off.....with all these jobs they are not usually simple....its a learning curve for you.....the exhaust should have come off as soon as you knew they wouldnt tap off.....it isnt the norm to leave them on, they are a replacable part......i have changed about half a dozen pairs over the years some tapped off and some needed cutting...its the same with any exhaust fittings
Cheers Steve, wise words. Just having one of those weeks where everything seems to going against me.
- Trev S -
#22 Re: Downpipe sealing ring/o ring removal
Post by Gfhug » Sat May 20, 2017 8:48 am
TrevS wrote: Cheers Steve, wise words. Just having one of those weeks where everything seems to going against me.
Trevor, we can all sympathise with that, and empathise with you. Others have kindly encouraged me when things just seem to be b....y awkward. You'll get there and enjoy being on the road when all this will have been forgotten.
#23 Re: Downpipe sealing ring/o ring removal
Post by mgcjag » Sat May 20, 2017 8:59 am
Where are you located Trevor.....very handy if you can find someone not too far away that can help or you can help, im quite fortunate i have 2 guys with Es that are also very diy....only a few miles away......maybee we should start up some kind of find a local helper :bigrin:
paulsco
#24 Re: Downpipe sealing ring/o ring removal
Post by paulsco » Sat May 20, 2017 9:05 am
Hi Trevor,
I would always replace the seal.
I would also avoid removing the down pipe unless it is your only option. You might find that you do not have enough space to remove the down pipe without further disassembly of the exhaust system.
As has been said, these seals are very soft metal and if they can't be levered off with a screwdriver, I would usually break them up using an old wood chisel. this cuts through the soft metal of the seal without damaging the rest of the down pipe.
Use it like you would on wood with the beveled edge facing downwards, so as not to cut too deeply into the metal.
Hugo
#25 Re: Downpipe sealing ring/o ring removal
Post by Hugo » Sat May 20, 2017 9:24 am
How about running a small drill vertically downwards to 'split' the ring? Maybe you can then lift one of the ends up & work from there?
TrevS
#26 Re: Downpipe sealing ring/o ring removal
Post by TrevS » Sun Jun 04, 2017 10:56 pm
Good news guys, sealing rings removed from both downpipes after a 4 hour session with a dremel with cutting disk. They were well and truly welded on but we've finally got them off without damaging the exhaust and am now ready to reassemble everything. I do have the small issue of fitting the studs to the manifolds though which I am struggling with viewtopic.php?f=3&t=10750
Trev
- Trev S -
TrevS
#27 Re: Downpipe sealing ring/o ring removal
Post by TrevS » Sat Jun 10, 2017 2:47 pm
Well nearly there. 1 manifold on and second has been test fitted. Would have been fitted fully but have a slight issue with one of the cylinder head studs not being quite long enough to fit a nut. Should be fixable and then ready for putting some heat cycles through next week. Still more work needed to get the engine bay up to scratch but the manifolds have made a big difference
- Trev S -
Hugo
#28 Re: Downpipe sealing ring/o ring removal
Post by Hugo » Sat Jun 10, 2017 2:59 pm
What happened to the (short) stud? Looks like a work of art in there!
#29 Re: Downpipe sealing ring/o ring removal
Post by mgcjag » Thu Jun 15, 2017 7:36 am
Another Spammer :helpsos:
TrevS
#30 Re: Downpipe sealing ring/o ring removal
Post by TrevS » Sun Jun 18, 2017 5:09 pm
Well after not being happy with the old studs I decided to replace them all. So everything had to come off the car and it's taken a while to do but finally the car is completely back together. So it's had new manifolds, studs, washers, nuts and sealing rings and I am glad I took the extra time to do the job properly.
So today was the first day running the car and I got quite a bit of burning smell and white smoke coming from between the downpipe and the manifold. I did use a healthy amount of exhaust paste so could it be this that's causing the smoke and will it pass?
I've only run the car once for 2 mins to put an initial heat cycle through the manifolds as per the instructions
Trev
- Trev S -
