Smiths clock replacement
#1 Smiths clock replacement
Hi there
Is there any supplier for a replacement Smiths clock the same as the original? Mine looks like it has already been modified and is broken so is suspect it may mot be possible to fix again.
Sydney Australia
Current
Jaguar Red Series 2 2+2 XKE 1969
Jaguar Italian Racing Red F-Type S 2014
Jaguar XJ6 Vanden Plas dark green 1985
Jaguar XJS V12 Silver 1987
Previous of interest
Jaguar XJ6 Sovereign series 3
MGA 1959
Current
MGA 1959
#2 Re: Smiths clock replacement
If the face of the clock is ok, why not send it to Mike Eck in the USA, very good service, fits a modern quartz movement but clock looks like the original:
http://www.jaguarclock.com/
#3 Re: Smiths clock replacement
Thanks, I already have been in touch with him and we are still talking but he is not sure he can fix it seeing as it has probably already been modified at some point in the past.
Sydney Australia
Current
MGA 1959
Current
MGA 1959
#4 Re: Smiths clock replacement
Unfortunately Mike (great communication by the way, would have loved to give him some business) has confirmed that he can't help me.
Still need to find a replacement
Sydney Australia
Current
MGA 1959
Current
MGA 1959
#5 Re: Smiths clock replacement
Caerbont Automotive Instruments in Swansea who are the successors to Smiths told me that they now re-manufacture a replacement for the Series 2 clock. Their web site is a bit impenetrable but the URL is:
http://www.smiths-instruments.co.uk
1969 Series 2 FHC
1969 Series 2 FHC
#6 Re: Smiths clock replacement
Thanks for that. Can't see it on the site, but I have emailed them, will see what they come up withjohnetype wrote:Caerbont Automotive Instruments in Swansea who are the successors to Smiths told me that they now re-manufacture a replacement for the Series 2 clock. Their web site is a bit impenetrable but the URL is:
Sydney Australia
Current
MGA 1959
Current
MGA 1959
#7 Re: Smiths clock replacement
The part number the Smiths guys wrote down for me was:
CT?2 3107-01HV
CT?2 3107-01HV
1969 Series 2 FHC
1969 Series 2 FHC
#8 Re: Smiths clock replacement
They do make one
CTE3107-01 clock - £132.80 including shipping to Australia.
Clock case is 60mm diameter, dial is white print on black background. bezel is 1/2'V' black.
Manufacturing lead-time is up to 4 weeks from order.
It looks like it will match the other dials in most respects, but it is not an exact copy in they it doesn't have the adjustment knob or screw.
I am going to keep looking for an original one for a bit but this is a backup option.
Sydney Australia
Current
MGA 1959
Current
MGA 1959
#9 Re: Smiths clock replacement
They do come up from time to time on eBay, if you aren't in a hurry. I was looking for a replacement Kienzle clock for my Series 3, which I eventually found. Which, by the way I do believe that the Later Series 2 cars were also fitted with the Kienzle (dependant what was left in the parts bin as the cars were coming down the production line).
You can probably get a new Kienzle from Welsh here;
http://www.welshent.com/product_info.ph ... 83_299_303
OR
They also have the Smiths here;
http://www.welshent.com/advanced_search ... ck&x=0&y=0
Alternatively, you can try Howard instruments located in Heidelberg, here in Vic, for repairs but I don't think you'll escape for anything under $300, if indeed it can be repaired.
OR
John Mann
1972 S3 Jaguar E-Type 2+2
1976 Jaguar XJ4.2C
2007 Jaguar XKR Portfolio
1976 Jaguar XJ4.2C
#10 Re: Smiths clock replacement
Thanks John. That second one is the one from my previous post, but they didn't have a photo, so nice to see it in the flesh.
Sydney Australia
Current
MGA 1959
Current
MGA 1959
Steve Marshall
#11 Re: Smiths clock replacement
Andrew
You could try John Ostick http://www.jdo1.com. He did a fine job of converting my S2 clock to quartz leaving the adjustments in place.
They are on holiday until 21st August though.
Nortonian mechanics Jan '69 S2 Roadster RHD Manual
#12 Re: Smiths clock replacement
Hello,
four years ago I did a DIY-conversion of the broken Smiths clock of my S2 to a quartz movement. I bought a donor quartz clock, namely from an old Ford Escort (Ford part no. 95AB-15000-BB), which is numerously offered for a few Euros e.g. on ebay. The wiring of the clock can easily be seen after dismantling. I soldered the step motor, the IC, the quartz, one resistor and two capacitors out of this clock. Then I took a perfboard, cutted it to fit into the housing of the Smiths clock and to be mounted to the original mounting points. I rearranged the parts from the donor clock on that board and rewired them. To adjust the clock two added micro push buttons on the perfboard are operated by the adjustment knob and the screw of the Smiths clock. They have to be pushed now instead of turned. Finally I mounted the original hands to the step motor. The whole efforts were some pleasurable hours on a rainy Saturday and total costs of about 20 Euro. The modifications are not visible and could be completely undone.
Joerg
Joerg
#13 Re: Smiths clock replacement
Nice one Joerg.
That is true ingenuity.
It's things like this that make restoration jobs so pleasurable.
