Ive just been congratulating myself on having successfully pressed a new large rubber bush into the radius arm using only a vice.....worked very well......only to discover that the two rubber holes arent aligned longitudinally as they should be but at a random 45deg ish....grrrr
Am I likely to encounter any problems if I leave it like this?
David
radius arm bush orientation
#2 Re: radius arm bush orientation
For competition work they usually re-orientate the bushes by 90° to stiffen the suspension but they usually do that to both. If one is 45° out make sure the other side is the same. No harm will come of having them both at that angle.
#3 Re: radius arm bush orientation
#4 Re: radius arm bush orientation
Oh thats great.....so instead of going out to the workshop and having to hack out my new bush Im simply going to open a bottle of red
Thank you very much for your replies.
best
David
best
David
David Offord
1972 Series3 ots
1972 Series3 ots
