Water jets
Edge
#1 Water jets
Post by Edge » Fri Aug 11, 2017 9:23 pm
What is the best thing to put underneath the water jets.
I've considered using either an o ring rubber washer or a fibre washer but can't decide which would be best.
Has anybody got any idea which I should use
Mark E Type Series 1 2+2 1967
Mich7920
#2 Re: Water jets
Post by Mich7920 » Sat Aug 12, 2017 7:21 am
Hi Edge,
If you look at the SNG jet C15645 you'll see that there is a rubber washer and a flat washer before the nut.
I did this and it's fine. The only thing is that the hole of the rubber washe must be too small, so you need to screw it on the water jet. Like this it's maximum watertight.
You'll need to have small hands to make this work !!
Mich
Michel
