Gearbox and carbs
Bernie2015
Topic author - Posts: 285
#1 Gearbox and carbs
Does anyone happen to know the rough costs for converting a LHD Series 2 2+2 auto to a manual 5 speed box and also changing the carburation to triple SU's from twin Strombergs
Bernie 1966 S1 OTS
#2 Re: Gearbox and carbs
Set of new SUs $5k plus a bit for sundries.
Gearbox figure on between $5k and $10k depending on what you buy. Plus say $1k for pedal box etc. Plus say another $2k for sundries (clutch, flywheel etc), trim bits etc etc.
Add say $2k to $5k if you get someone else to do it.
#3 Re: Gearbox and carbs
Don't forget the modifications to the transmission tunnel and radio console etc.
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
#4 Re: Gearbox and carbs
There's no real need to modify the tunnel going from auto to manual - it just looks a bit wider, as indeed it is
#5 Re: Gearbox and carbs
Hi Bernie....do you also want to convert to RHD........steering rack getting hard to find.....plus changing the dash......and will you also want a diff change
Bernie2015
#6 Re: Gearbox and carbs
Thanks for the replies chaps were those prices in $ or £
Bernie 1966 S1 OTS
#7 Re: Gearbox and carbs
Hi Bernie...Andrew is in Australia....so Aussie $ ...Carbss are approk £3.5k..pedal box not sure but £750, second hand gearbox £1.5k rebuild £1k ...bellhousing clutch etc £1k.....steering rack £1k.....dash etc £1k.....diff £1k...plus labour...just a rough guesstimate.....Steve
Bernie2015
#8 Re: Gearbox and carbs
Thanks Steve much appreciated
Bernie 1966 S1 OTS
