Many thanks to all who have helped me in the past. Another query - what are the dimensions of the drain tubes for the "sugar scoops" and are they readily available?
Greg
Drain tubes bd28539 - headlight scoop
Factory used cheapo garden hose. Find anything in black to do it!
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
Honestly, who would make Jaguar sink so low1954Etype wrote:Factory used cheapo garden hose.
chris420sa
#5 Re: Drain tubes bd28539 - headlight scoop for Series 3
Hi All - I know it's some time since this topic was raised but can any member please advise where the drain tube connected to the headlamp scoop drain should terminate? The more practical solution, rather than strict compliance to the original, to avoid the water causing future rust problems would be greatly appreciated.
Look forward to responses and many thanks in advance.
Best regards
Chris Davies
Best regards
Chris Davies
Chris Davies
1972 Series 3 2+2
1972 Series 3 2+2
#6 Re: Drain tubes bd28539 - headlight scoop
I would recommend having them a little longer and route them out of the bonnet, from memory there are two options for exit.
Pat
Pat
