Symptom #3 is insufficient manifold vacuum. I’ve tried everything to fix this: blanked off the carb bypasses, repaired the gulp valve, capped all other manifold tappings (for filter box hot air diverter valves and carb bypass valves) and capped the throttle edge tappings. All to no avail; vacuum vibrates around -7”Hg, should be steady around -20? Here is video of the vacuum valve, just started, still on choke …
https://1drv.ms/v/s!AiSPBKa26IcchJolgPRvVdkcJwNZCA
Symptom #2 is the clatter you can hear until it warms up. Just a bit of piston slap I tell myself, nothing to worry about …
Symptom #1 is the clouds of acrid smoke. Having to remove my (stinking) clothes before being allowed into the house is becoming tedious. And now even the neighbours are asking (very nicely) if car tuning could not coincide with their outdoor dinner parties?
I’m thinking, if there is no manifold/carb vacuum leak it must be valves, this would also explain the acrid smoke? Might there be anything else I could/should check before pulling the heads off?
