Starting Without Choke
PAUL MORRIS
Topic author - Posts: 344
#1 Starting Without Choke
Dear All,
I recently cleaned every wire visible & changed what i felt damaged.
Also used equivelent of WD40 where I thought best in addition to new connections etc. As a result the engine fires First time as cold with no Choke whilst before it needed nearly Full Choke. Would you advise to still use the Choke ?
Thks
Thks
Hello Paul,
For cleaning the wire, you could use a "bombe contact ?lectrique" you may find in a a supermarket (like "super u" for me). It would be better than wd40 which will let some "gras" on the wire.
For the Choke, The less you use it and the better is: I don't use it when it's not necesary. (but , please wait for a better and more technical advice).
PS Have you planned to go to the GPAO in burgundy or in "Le Mans Classic"? :bye:
#3 Re: STARTING WITHOUT CHOKE
You might find that the mixture is too rich if you dont need chokePAUL MORRIS wrote:Dear All,
Thks
PAUL MORRIS
Dear Frogeater,
Now thats a good name, its just tates like excellent chicken anyway.
I never knew where to buy them to be cooked I eat Rabbit but never tell the Children as they will be sick. I cant get to Classic events so much yet as My Wife has not digested the Car yet, in fact I am not sure she ever will. I might go the Hill climb race 10km from my house Chanteloup les vignes, maybe it was invented their I will look up.
Sushi man (26 years of Mitsubishi)
PAUL MORRIS
#5 HILL CLIMB RACE
Dear All,
Please kindly kindly note that on the 6th at Chanteloup-les-Vignes a hill climb race will be held for the 112th edition being the Worlds Oldest. Also it seems a 64 Etype is racing, certainly not me, I am broke.
Chaque ann?e, un groupe de passionn?s fait revivre un pan de l?histoire chantelouvaise avec le meeting de la course de c?te, qui f?te cette ann?e ? son 112?me anniversaire. Ce rendez-vous r?unira des passionn?s de voitures anciennes, qui reprendront l?ascension de la c?te historique, limit?e aujourd?hui ? 900m pour une pente de 14%, au volant de voitures mythiques.
JAGUAR TYPE E 1964, DELAGE D6 17 3 litres 1931, AUSTIN ULSTER SPECIAL 1930, BUGATTI SALMSON S4 1931, HISPANO SUIZA H6B, LAMBERT BOL D?OR 1949? sont quelques-uns des mod?les qui seront pr?sents le 6 juin prochain. Depuis quelques ann?es, motos et side-cars ont rejoint les voitures. Spectacle garanti !
Rendez-vous dimanche 6 juin au parking St-Roch d?s 10h00 pour la premi?re ascension de la c?te de l?Hautil, suivie de deux autres ? 14h00 et 16h00. La remise des troph?es aura lieu ? 18h00.
f June a Hill Climb Race will be
PAUL MORRIS
For those of You who speak English & dont Eat Frogs please find the Link below. See You At the Race with Some Wine & Smelly Cheese
http://mg4sale.free.fr/course-chantelou ... 07-en.html
Hello Paul,
I must confess, I never try to eat a frog. I choose this name on this english forum, just because of the wellknown "prejug?".
Thank you for the link you put, but I won't be able to come.
I hope that your wife will come and find that you are not alone to buy these "silly rusty things". Time may be great in that matter.
My girlfriend find that the e type in fhc dark blue (like yours) is the most beautiful car (even if she doesn't see the point to drive it, and prefer to look at her in a garage).
(Very happy for you, that your problem of engine oil was solved without great expenses.)
The councel of 1954 etype have to be heard: do you mean that you don't need any choke after one week at a ugly morning weather or just after some hours letting the car in a sunny place?
PAUL MORRIS
Dear Frogeater,
My wife certainly wont come for sure, for the Choke its a cold start at about 6c in May. By the way how far do you push the engine on the Rev counter ? What is your max speed ?
In my experience the XK engine needs full choke to start from cold and you can then gradually reduce the amount of choke as the engine warms. The speed of reduction will depend on ambient temperature but after about 5 miles you should be able to run without choke. Remember on the E-Type the first movement of the choke lever should only increase idling revs, further movement adds the choke. Each engine is different so you will need to learn what works for you. Only problem with using the choke is the enriched mixture can produce 'bore wash' - i.e. unburnt petrol washes the oil off the cylinder walls increasing wear but as long as you are circumspect in removing choke as soon as possible it should not be a problem.
Paul,Heuer wrote:In my experience the XK engine needs full choke to start from cold and you can then gradually reduce the amount of choke as the engine warms. The speed of reduction will depend on ambient temperature but after about 5 miles you should be able to run without choke. Remember on the E-Type the first movement of the choke lever should only increase idling revs, further movement adds the choke. Each engine is different so you will need to learn what works for you. Only problem with using the choke is the enriched mixture can produce 'bore wash' - i.e. unburnt petrol washes the oil off the cylinder walls increasing wear but as long as you are circumspect in removing choke as soon as possible it should not be a problem.
Same for mine, must use maximum choke when the engine is completely cold. Once stated move the choke to mid-way to get out of the drive and onto the street. The fast running position is usually adequate for the next couple of miles although for safety I use some choke at stop junctions until it's warmed up. I suspect it's running rich if yours is not similar.
1963 OTS
Hello Paul,PAUL MORRIS wrote:Dear Frogeater,
I can't answer you to that question for the simple reason I never drove a jaguar.
I've exchanged in 1996 a 504 coup?, against a daimler xj6 s?rie1 but the car have an engine ceased (and also a rotten body) so I gave it to a personn in 2000.
In 1997, I've bought my etype to restore and I hope the restoration will be finished in some months.
I've bought a mk2 3,4 in 1997 or 98 to restore also, and this car is awaiting the finishing of the e type and perhaps that I have also the time to do all the mechanic by myself, because I would want to make a complete mechanical restoration once in my life....
I must add, that on all my driving cars (classic and modern) I never push hard and change the gears at nearly 3000rpm (sometimes less)
So please, wait for more experts personns to answer you on this post
#12 Full choke: still not enough when cold
My car is very difficult to start when cold, and not used for >1 week.
Full choke, and 6-8 tries will eventually get it going.
OK, during that time I build up a little oil pressure and splash about the oil in the lower regions, but perhaps I need to adjust.....?
Same here. If I use the car every day it starts on the first crank of the motor. Leave it for a week and it can take five or six goes to get it going. Leave it a month or longer and it takes even more churning. Personally I think they really are like cats - they sulk if you do not give them attention
#14 Re: Full choke: still not enough when cold
If the car's not used for more than a week I find leaving the fuel pump run for a minute before pushing the button works well.pmansson wrote:My car is very difficult to start when cold, and not used for >1 week.
1963 OTS
And somebody told me to push the gas peda to the bottom twice, before attempting to push the button.
That should make no difference unless you have Webers on the car. SU's do not have a throttle injection pump so pressing the pedal will have no effect unless you turn over the engine at the same time.
