Thinner than usual valve pads
Philippe-J.
#21 Re: Thinner than usual valve pads
Post by Philippe-J. » Thu Jun 25, 2026 11:15 am
Next, and hopefully last, episode of the story:
I ended up ordering a new set of valves to Rob Beere Racing, I received them, I installed them, I measured the clearance between valve tips and cams, I inferred the needed new shims, and they all, but one, fall within the commercial available range :bouncyyellow:
The thinner one is just 3 thou lower than the thinnest commercial one. Rob Beere advised me to grind or rub off a few thou.
This story confirmed that not only do Rob Beere provide the right stuff, they also are very helpfull :thumbsup:
Philippe-J
#22 Re: Thinner than usual valve pads
Post by Gfhug » Thu Jun 25, 2026 6:33 pm
That’s good to hear Philippe. Keep us aware of how you progress
Stevemorris
#23 Re: Thinner than usual valve pads
Post by Stevemorris » Fri Jun 26, 2026 8:16 am
Sounds like you are getting there Phillippe!
So you are just replacing the valves? If it were me, and the head is clearly off at the moment, I would be inclined to fit new seats. If the new valves are giving you a 'close to the lowest' shim requirement, I would be much happier for long term fix if the shim requirements were either in the middle of the shim range or at the higher end? It's so so easy to do the seats now, so why wouldn't you?
Just to clarify, when Rob Beere says 'grind' the shim he doesn't mean on a grinding machine, this is a job best done by hand. It takes a long time but doing it 'cold' means the shim will retain its hardening. The shims loose this when they get hot on a grinding wheel..
Also, when you say 'commercially available' shims, assuming you mean from SNGB? They can supply shims down to 0.075" now (previously only available down to 0.085"). If you are having to take one of yours below the smallest available shim from SNGB I would say you definitely need to do the seats?
Sorry to appear negative but just trying to help!
Steve.
Steve, UK.
1965 Jaguar ‘E’ Type FHC
Philippe-J.
#24 Re: Thinner than usual valve pads
Post by Philippe-J. » Fri Jun 26, 2026 9:31 am
Hi Steve!
Thank you for your remarks & advise. I think I can confirm your points:
- according to the local workshop the original seats needed not to be renewed, just reground. They were not that worn. The issue I had appeared to be due to a wrong model for the valves. It was cleared off with the ones Rob Beere provided, except for one: it requires a 0.072" shim instead of 0.075" which is the lowest available at SNG. The others go up to 0.095". So for budget sake, I elected to keep my original seats.
- There was another reason. The above local workshop failed in the middle of their work for my engine. So they were out for a valve renewing job. The second workshop did an excellent job in surfacing the head, honing the cylinders and so on, but proved reluctant to renew the valves. I wouldn't want to force them in a job they were not volunteers in, would I?
- Yes Rob Beere advised to grind this shim by hand with sandpaper. I asked him if I should polish it afterwards, he said "No just rub it and hold in a valve spring retainer cap 👍". Your explanation is welcome, however.
- Yes I ordered my shims to SNG. They sell an extended range, even if not obvious to be found on their site (guess why I'm saying that). Rob (again) told me you can thin a shim down to 0.060". You can shorten the valve stem too, but it is a bit more difficult to stay perpendicular to the stem axis.
- I have to add that I change the guides, springs and tappets too.
Philippe
Philippe-J
#25 Re: Thinner than usual valve pads
Post by Series1 Stu » Fri Jun 26, 2026 10:16 pm
Stevemorris wrote: ↑
Absolutely not the case. The only way to properly grind shims is on a surface grinder. Otherwise, you just won't get accurate and parallel thickness of the shims. The process of surface grinding removes a very small amount of material at a time and doesn't generate any amount of heat that would affect the temper of the material. There is also the option of using coolant to minimise the temperature of the material.
Unfortunately, most of us don't have access to a surface grinder so have to resort to emery paper on a sheet of glass.
Also, there seems to be a misconception that shims are case hardened. They are actually through hardened, so don't worry about spoiling the temper.
Philippe-J.
#26 Re: Thinner than usual valve pads
Post by Philippe-J. » Sat Jun 27, 2026 7:59 am
Stuart,
is the "surface grinder" associated with some sort of "magnetic vice" I heard about? I understood that a "magnetic vice" is necessary to hold the small shims while grinding them. This equipment is rare for individuals like us.
Philippe-J
#27 Re: Thinner than usual valve pads
Post by Series1 Stu » Sat Jun 27, 2026 9:20 am
Yes, Philippe, that's correct.
They are high precision machines that generally incorporate a magnetic bed. When items are quite small you need to make sure they are positioned on the bed so they get maximum magnetic field to avoid them being thrown off when the wheel hits them. It's a skilled process.
Obviously, they won't work with non-magnetic materials.
MSM
#28 Re: Thinner than usual valve pads
Post by MSM » Sat Jun 27, 2026 11:29 am
That is very interesting. I had always understood that the shims were case hardened and thus not really adjustable but learning that they are through hardened is good news for future reference.
Mike
Mike
angelw
#29 Re: Thinner than usual valve pads
Post by angelw » Sat Jun 27, 2026 10:31 pm
Hello Stuart,
How have you determined that the original, or after market shims are through hardened?
For quite awhile, I've been considering manufacturing tappet shims, but haven't got around to determining the material to use. A hardness test indicates a surface hardness of circa 60 RHC, with my first thought that a through hardened piece of the typical thickness of these shims would be too brittle for the cyclic pounding they are subjected to. My next step in the dance, which is the one I've not got around to, is to definitely determine if the shims are case hardened, by a process called macro-etching or metallographic cross-sectioning. This can be done by cutting a shim circa in half along a chord of its circular shape, not in half thickness wise, then polishing the cut face. After polishing, apply Nitric acid to the cut face to etch the surface. In case-hardened carburized steels, the core is lower in carbon and will appear dark, while the high-carbon case will appear lighter.
It's not just a case of having a magnetic bed (magnetic chuck) and positioning, the magnetic chuck needs to be fine-pole (or micro-pitch) magnetic chuck, which is engineered specifically to prevent the magnetic field from passing completely through thin material. Unless a machine shop does thin thickness work piece surface grinding, its unlikely they will have the required magnetic chuck to do the work. Accordingly, you won't be able to take shims along to any machine shop to have them ground to size.
One other method of work holding thin material for surface grinding, and it works for non magnetic material, is to use a "freeze chuck" or "ice chuck". It uses water as a bonding agent, rapidly freezing it into a thin, solid layer of ice that firmly holds parts in place without applying clamping pressure. This is very useful where the surface of a thin part that would interface with a magnetic chuck is not perfectly flat, and due to its thinness, the not so flat surface is pulled down flat onto the surface of the chuck. When the magnetic clamping force is released, the part will generally revert back to its original state, and the surface that has just been surface ground flat, will no longer be flat. A Freeze Chuck will normally only be found in shops that do a lot of thin, or non-magnetic material grinding.
rfs1957
#30 Re: Thinner than usual valve pads
Post by rfs1957 » Mon Jun 29, 2026 7:14 pm
Based on a lifetime of Ducati cylinder head work, I couldn’t count the number of times when I’ve either shortened valve-tips, or come across engines where someone else has done it.
I’m not a metallurgist, and don’t know much is « safe », but I wouldn’t think twice about grinding 1mm off if it took me into an easier shim range.
Chesmans of Coventry properly butchered a couple of new valves when they rebuilt my new-seats and « ready to fit » head, albeit with no oil ANYWHERE and a whole host of other botches, keen students of the genre may remember, but only because the ends were free-hand ground and nowhere near square.
Which makes me think that if it’s done properly there’s nothing wrong with it.
A whole lot easier than grinding shim after shim.
Bill ?
PS Hailwood’s Ducati, in either 1978 or 1979, at the Isle of Man TT, saw the Ducati factory mechanic Pedretti and Steve Wynne of Sports Motorcycles grinding shims on the stone of a Douglas hotel steps.
Philippe-J.
#31 Re: Thinner than usual valve pads
Post by Philippe-J. » Tue Jun 30, 2026 8:25 am
Rory,
In 1978 or 1979 I would have been too young to appreciate the scene of Ducati factory mechanic grinding shims on the stone of a Douglas hotel steps, but today I can figure out the image :bigrin: !
Your sad experience of Chesmans of Coventry with valve-tip grinding pushes me to have a try on grinding the only lower than out of range shim I need. It is the advise of Rob Beere, too.
I'll keep you informed.
Philippe-J
angelw
#32 Re: Thinner than usual valve pads
Post by angelw » Tue Jun 30, 2026 10:55 pm
Hello Rory,
There is a corresponding dimension between the bottom of the pocket in valve spring retainer and the end of the valve. Accordingly, if there are only few valves concerned, I would machine the end of the valve stem to reinstate a dimension that's reasonable, and in doing so, would circumvent grinding shims.
Grinding the end of a valve stem is a lot easier than grinding shims, and every cylinder head refurbishment business, if not all engine rebuild shop, would have a valve grinding machine, which incorporates a valve stem end grinding feature. Accordingly, Philippe could determine the amount of material to remove from the end of the valve stems so that the shims required fell into the scope of recommended size, take the valves along to the nearest cylinder head reconditioning business have have the job completed in a timely manner. He will have a far better chance of the first cylinder head reconditioning shop that he visits having the correct equipment, than finding a machine shop that has a close pole magnetic chuck, or freeze chuck to do the job.
I'm still not convinced that the shims are through hardened. My engineering gut tells me Case Hardened, and unless I'm shown otherwise by either material analysis, or metallographic cross-sectioning, I'll stick with that.
Philippe-J.
#33 Re: Thinner than usual valve pads
Post by Philippe-J. » Sun Jul 19, 2026 6:40 pm
Well, time to explain how I got through this issue.
I elected to grind the thinner shim, from the thinnest available at SNG. I made a special tool to handle the shim, and pushed it back and forth on a sand paper, or in circles, laid onto a thick piece of glass.
It is sort of a spoon, with an embossment in the middle of the recess, in order to apply punctual pressure on the shim so as not to make any wedge in it.
"Very clever" I thought, immodestly. My problem occurred elsewhere: in the math I made to calculate the shims I needed! Almost none gave the correct clearance, eventually :banghead:
So I had the choice between ordering a new set, which supposes that I made the correct math this time :?: , and results in a week delay due to postage. Or, grinding the shims myself, which takes a lot of effort and time, but less than a day (so I thought). I took the later path. Actually it took me the whole week-end, in a try and error process, some valves required 4 or 5 steps before converging to the famous 0.004" and 0.006" clearances (which validates the choice not to purchase the shims at each step).
The only thing I found to speed up the process is to alternate gross and fine sand paper, finishing with 2000 grid to kind of polish the surface.
To my relief, I can now move to the next step: reassembling the block and the head :drinkingcheers:
Philippe-J
rfs1957
#34 Re: Thinner than usual valve pads
Post by rfs1957 » Mon Jul 20, 2026 2:22 pm
In future, grind the end of the valve stems and get yourself into the available range of shims, as you will have to do this all over again once the gaps start to close up.
Either way, you did better than you would have done on the steps of an Isle of Man hotel.
But you didn't win a TT, mind.
angelw
#35 Re: Thinner than usual valve pads
Post by angelw » Tue Jul 21, 2026 9:55 pm
Yes, and its's highly likely that his valves as they are now from seat to stem end (effective length), are not the same, therefore, grinding the end of the stem is not introducing an error, given the small amount he is chasing. It's a very common process to carry out and with a valve grinding machine that every engine builder is likely to have and cylinder head refurbishing companies are certain to have, finding someone to do the job in a timely manner would be easy.
rfs1957
#36 Re: Thinner than usual valve pads
Post by rfs1957 » Wed Jul 22, 2026 9:53 pm
I am sure Philippe would have followed this advice had he not been a little too far advanced in his assembly, frustrated by delivery issues, and he was actually confronted with only one valve that fell outside the standard range.
As long as he gets ahead now, by preparing a few thin shims for when his gaps start closing :hammerdrill:
I just write down what is fitted and make sure I have a bit of depth in my shim box to cope.
Whoever buys my car will be amazed at the 20-year foresight my stock betrays, but will understand why such Single Issue Fanatic behaviour drove me to an early grave :lol:
angelw
#37 Re: Thinner than usual valve pads
Post by angelw » Thu Jul 23, 2026 12:34 am
Rory Wrote:
I’m sure Philippe would have followed this advice had he not been a little too far advanced in his assembly, frustrated by delivery issues, and he was actually confronted with only one valve that fell outside the standard range.
True enough if the head was installed on the engine block, but from Philippe’s opening Post, where valve seats were being ground, and new valves fitted, you would be nuts to not set the tappet clearance while the head was off the engine. In that case, to remove one valve to have the stem end ground a few thou, as opposed to lapping a shim would be a no brainer.
