Series 2 aesthetics
#201 Re: Series 2 aesthetics
Hi Marek
I have your original led reversing lights. Are you able to swap out those for the new ones, or do you need to replace the whole unit?
#202 Re: Series 2 aesthetics
The new boards are a press fit into the clear Lotus bit of the rear lenses.
Since yours date from May 2016, I'm guessing you'd have to use a scalpel (or Dremel) to cut a hole in the back of the lenses to be able to remove the old LED board. Alternatively, delicately inserting a scalpel between the clear housing and the main body may pry the clear part free.
Later units are a simple swap over as they are unsealed.
#203 Re: Series 2 aesthetics
Are the LEDs "E" marked, like bulbs have to be? I have had a ticking off from the authorities for the reversing lights on the MOT test
-Mark
#204 Re: Series 2 aesthetics
The MGB square lights used by Jaguar will have had markings on them. The clear inserts that make a standard s2 or s3 rear light into a "Lotus" light never had any markings on them. All I have done is change the festoon bulb for a brighter array of LEDs, neither of which ever had markings.
The markings on the s2 or s3 main orange/red rear housings are exactly as before.
Jeff Cecil
#205 Re: Series 2 aesthetics
#206 Re: Series 2 aesthetics
Jeff, those lights look interesting, tell us more, please
#207 Re: Series 2 aesthetics
MGB rears.....Steve
Jeff Cecil
#208 Re: Series 2 aesthetics
#209 Re: Series 2 aesthetics
Here's a couple of pics of Marek's LED reverse lights in action. White for reverse, red for brakes. Very cool!
- Attachments
- ec00864b028048a0394977f7fe40b61d761d3b84_2_666x500.jpeg (138.8 KiB) Viewed 25406 times
- e03f0d196977e2805f691e541b7e77aa6263890d_2_666x500.jpeg (164.12 KiB) Viewed 25406 times
Bob t
LHD '69 OTS. (Former) basket case
#210 Re: Series 2 aesthetics
Jeff Cecil
#211 Re: Series 2 aesthetics
Jeff Cecil
#212 Re: Series 2 aesthetics
#213 Re: Series 2 aesthetics
Ok.....dont like the colour of the rear numberplate....dosnt really go with the paintwork.....and dosnt look straight
#214 Re: Series 2 aesthetics
And the sky is way too blue, it needs clouds.
Jeff Cecil
#215 Re: Series 2 aesthetics
Jeff Cecil
#216 Re: Series 2 aesthetics
#217 Re: Series 2 aesthetics
If you're looking for comments on atheistics, it's got to be about the super wide Series 2 rubber bumper to body seal. Far from worrying if the number plate is straight, change that rubber strip for the Series 1 narrow one today.
1969 Series 2 FHC
1969 Series 2 FHC
#218 Re: Series 2 aesthetics
Hi Jeff. Trying to get in touch with you..I’m in SC. Could you email me.
Enoreeriver at gmail. Thanks! Anthony
Jeff Cecil
#219 Re: Series 2 aesthetics
#220 Re: Series 2 aesthetics
Jeff, do you have the information on how you did that, please?
S2 4.2 FHC
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
"You only live once, but if you do it right, once is enough..."
Ford F100 pickup
JAGUAR S-type
BMW R1300RS
