Bernie2015
Post
by Bernie2015 » Thu Mar 30, 2017 12:07 pm
Bernie 1966 S1 OTS
- Moderator
Post
by mgcjag » Thu Mar 30, 2017 1:27 pm
Hi Bernie.....you can adjust the doors....requires the hinges moveing....these doors are heavy and on a 2+2 that area is always difficult to get to look correct....also dosnt help if tne doors have been ever been re skinned....you can try yourself but might be earier to get a body shop to look at it.....mask up all the edges becaus its very easy to damage even more paint
Bernie2015
Post
by Bernie2015 » Fri Mar 31, 2017 8:03 am
Many thanks Steve will probably get a body place to do it
Bernie 1966 S1 OTS
- Moderator
Post
by 1954Etype » Sat Apr 01, 2017 7:44 am
Before you go to the body shop, make sure you have minimal play in the door hinges. If they are worn (and the 2+2 hinges wear quickly once they start to go) there is no point trying to set them up.
Hinges can be re-pinned.
Bernie2015
Post
by Bernie2015 » Sun Apr 02, 2017 6:22 am
Hi Angus checked it and no movement but thanks for the advice
Bernie 1966 S1 OTS
tim wood
Post
by tim wood » Sun Apr 02, 2017 4:14 pm
Hi Angus, do you have a contact who can repin these?
Tim
- Moderator
Post
by mgcjag » Sun Apr 02, 2017 5:09 pm
- Moderator
Post
by 1954Etype » Sun Apr 02, 2017 5:31 pm
Hi Tim, if you can't do them yorself using the article Steve posted, we can get them done for you. Let me know off line if you are interested. Angus
