Lucas relays
#1 Lucas relays
Not sure if this is any use to anyone but here you go..
Handy little list of 6RA relays etc from the TVR club.just click on the first google suggestion.
It’s from the club across the pond.
http://tvrna.tvrccna.org/lucas/lucas-relays-6ra.htm
If I’m behind the times accept my apologies.
Peter
Peter
Peter {XKE V12HE efi}
XKRS
Octavia VRS.
XKRS
Octavia VRS.
#2 Re: Lucas relays
Excellent.....many thanks for posting....
#3 Re: Lucas relays
I have this as a PDF.
David do you want it for the KB?
#4 Re: Lucas relays
I think a .pdf file in the knowledge base is an excellent idea.
Ross
1972 Series 3 E Type 2+2
1972 MGB GT
1965 Mini Cooper
1954 Austin A30
https://rossjohnsonphotography.zenfolio.com/
1972 MGB GT
1965 Mini Cooper
1954 Austin A30
#5 Re: Lucas relays
Aside from the starter motor relay, you can usually make what you need out of a changeover relay. For most of the variants used on the car, simply externally connect the c2 terminal to one of the w terminals and leave the unwanted terminal unconnected.
#6 Re: Lucas relays
If you click on the original link just then click print and the pdf is usually created...save or print. ..!
Peter
Peter
XKRS
Octavia VRS.
XKRS
Octavia VRS.
#7 Re: Lucas relays
Steady on lads. This has the potential to be a ‘super-spreader’ file... Using anything from the TVR crowd could turn our cars into fibreglass with half-inch panel gaps, and make the dash switches and window winders snap off after first use!Fspp369 wrote: ↑Fri Feb 05, 2021 5:21 pmNot sure if this is any use to anyone but here you go..
Handy little list.. from the TVR club across the pond.
http://tvrna.tvrccna.org/lucas/lucas-relays-6ra.htm Peter
#8 Re: Lucas relays
Ahh Yes but once you've been impregnated, once now and if necessary, again later (yet to be decided) you won't get any body rot
XKRS
Octavia VRS.
XKRS
Octavia VRS.
#9 Re: Lucas relays
Already in the KB, been there since August 2018 but thanks for the thought.
