Fuel lines in and out of fuel filter
#1 Fuel lines in and out of fuel filter
I could use your advice again.
One of the PO's has installed a plastic inline fuel filter between the fuel filter (engine bay) and the carbs. A rubber hose was used. I would like to replace it with something that looks like from the factory fit series, like this one in post #156
http://forum.etypeuk.com/viewtopic.php?p=58073#p58073
It is transparent and must have gotten a brown tint with age. The replacements for the carb feed line C17335, which I have found at SNGB and Oldtimerteile Idstein (Germany) are opaque white and have a brass banjo that is narrower than the one shown above. My banjos are plated like C17335/B from SNGB.
What can I use instead? Did one of you replace the tubing with transparent nylon PA12 and could the stock banjo be used for it?
Thanks!
Thanks!
Klaus
#2 Re: Fuel lines in and out of fuel filter
The tube was originally white but discolours to brown with age. You can buy a length of the white tube and use the existing fittings. The tube is a very tight push fit onto the fittings so the trick is to heat the fitting in a vice and once it is hot push the tube on.
#3 Re: Fuel lines in and out of fuel filter
#4 Re: Fuel lines in and out of fuel filter
Thank-you, David and Christopher,
I will follow your advice, get white fuel line tubing and make the feed line myself. I will report on the result.
Klaus
Klaus
Klaus
#5 Re: Fuel lines in and out of fuel filter
And?
Jaguar MK2 1967 since 1980
Lotus Seven 1963 since 2015
XKE S1 1964 OTS since 2023
Stevemorris
#6 Re: Fuel lines in and out of fuel filter
I am interested in this thread as my pipework has been replaced with what looks like gas bbq hose (the red/orange stuff). Ive done a quick search and can't find the clear hose?
Thanks, Steve.
Thanks, Steve.
Steve, UK.
1965 Jaguar ‘E’ Type FHC
#7 Re: Fuel lines in and out of fuel filter
I found suitable nylon hose at a hydraulics supply co.
Randall Botha
#8 Re: Fuel lines in and out of fuel filter
The hose isn't clear it's white....the usuals sell it but I think now only with fittings already attached....this not too expensive and a long length....Steve https://ebay.io/m/6IHSZY
Monkeyfinger
#9 Re: Fuel lines in and out of fuel filter
In case it's helpful - when I made up replacements for my fuel lines, I pressed the barbed fitting into the tube without heat. Having seen the method online, I used a standard caulking gun, with part of an old flaring tool to clamp the pipe, and squeezed the fittings in by pulling the trigger. Worked a treat.
Of course, I didn't take any pictures of my system, but it seems you can actually buy a tool that does the same thing, if you don't enjoy the Heath Robinson approach
