Beginner
Post
by Beginner » Mon Jan 24, 2022 9:36 pm
H all,
Here I am with my newly and fully restored 1961 flat floor e type !!
Only drove 1100km so far..looks and sounds great..!
Except exhaust manifold getting enamell cracked after normal driving..
Where to get good quality enamalled cast iron??
1961 XKE OTS N° 875758 matching numbers
Driving slowly
and leaving fast will take you old and keep you young..!
Post
by Gfhug » Mon Jan 24, 2022 9:45 pm
Welcome to the best place for all things E Type. Do you have a name? Please add it to the signature area, it’s much nicer to address you correctly.
As for cracked manifold enamel, it is a common problem. Read this topic and it will help explain some things people try:
viewtopic.php?f=2&t=17026
A well known journalist said that if the enamel hadn’t cracked then you weren’t driving the car hard enough!
frogeater
Post
by frogeater » Mon Jan 24, 2022 10:29 pm
Hello,
Welcome to this great forum without any correspondence in France.
Where are you placed in France?
Emmanuel. PIR27059 in restored condition to COMPLETE Européen condition (except power steering)
Polse7317
Post
by Polse7317 » Tue Jan 25, 2022 9:00 am
+1 welcome
Looking for a OTS 4.2 serie 1....!
and now have found a fhc xk 140
Beginner
Post
by Beginner » Tue Jan 25, 2022 11:48 am
I am located near Strasbourg close to the german border...
Driving slowly
Post
by malcolm » Tue Jan 25, 2022 4:00 pm
Hi and welcome to the forum!
Post
by Gfhug » Wed Jan 26, 2022 6:07 pm
Phil, have you contacted SNG Barratts as you would have seen they have new manifolds if you’ve read the topic I linked to?
- Administrator
Post
by Heuer » Thu Jan 27, 2022 11:13 am
SNGB also ffer the cast manifolds in bare metal so you can treat them with BBQ paint. This lasts a long time and is easy to reapply and touch up when necessary. The porcelain finish crazes and cracks with rapid temperature changes caused by enthusiastic driving or when rain water hits them. Brake in the rain and water rushes dwn the screen and bonnet iunto the louvres and on to the hot manifolds.
