Hi All,
I have contacted Autosparks to make a new wiring harness for my car. (S1 2+2 1E50739) A minor concern is the only harness plans they have are for a harness with the brake pressure switch position on the lower left picture frame but they have kindly offered to help. They acknowledge having read on posts that some cars around mine had the switch located on the lower left firewall and have asked for and I have sent a photo of my original harness. Have others encountered this and any suggestions?
Thanks again,
Peter.
Brake light pressure switch position
#1 Brake light pressure switch position
E type series 1 2+2
XK 140 DHC
XK 140 DHC
#2 Re: Brake light pressure switch position
Hi Peter...does this help viewtopic.php?f=4&t=1128&p=6466&hilit=B ... tion#p6466
#3 Re: Brake light pressure switch position
Thanks Steve,
Same problem with a car built around that time. I'll let you know how Autosparks reply. They appear to want to help.
Thanks Peter
Thanks Peter
E type series 1 2+2
XK 140 DHC
XK 140 DHC
#4 Re: Brake light pressure switch position
Peter, you might like to consider adding a mechanical brake light switch as explained here:
viewtopic.php?f=9&t=3134
A popular and well thought of upgrade.
#5 Re: Brake light pressure switch position
Thanks Geoff
It appears others have had problems with the standard pressure switch. Never knew the Series 3's changed to an electric switch and it's probably worth doing. Thanks again.
E type series 1 2+2
XK 140 DHC
XK 140 DHC
